Smitty Toyota Conversion Angle Drive
RDKeysor
Bronze
I have a '60 BN7 that came with a Smitty Toyota gear box conversion. I have twice adapted cables to fit the speedometer drive on my car's gearbox, likely a W57, but that is speculative. I also have done a 3.5 differential conversion. The angle of approach for the speedometer cable is forces a tight bend, and I think that has contributed to the speedometer needle hop I have experienced with the two different-length cables I've tried. I'm wondering if a Toyota angle drive might solve the problem. And I'll add that I don't find these for sale on eBay. Has anyone found a source for these units, is there any gearing issue involved, and what might either a new or used drive cost? As mentioned at the outset,I have successfully attached the Toyota drive fitting to a standard Healey cable and assume that piece fits into the angle drive????
If the needle hop is rhythmic and speed-related--as opposed to random--the hop is likely due to a fractured odometer or trip meter drive gear.
You'll be hearing from fans of GPS-driven units.
red57
Do you have one of these? Toyota part # 83770-22100.
It's not a gear drive like stock Healey, it's a large radius sweep 90* with a cable inside. I have never changed it and never replaced a cable and always had smooth a needle with this set-up and I'd guess at least 75k miles since I installed it in 1997.
Smitty's parts page.
R
RDKeysor
Bronze
My speedometer needle fluctuation is rhythmic and thus, as one respondent says, may be due to an internal failure in the instrument. I have had the speedometer apart in the past and didn't find the issues mentioned, but I may give it another look. A second responder offered something that I have never seen, the Smitty parts list. My car came with the gearbox installed and fully functioning, and the instructions did not accompany it. I was happy to see that there is an alternative to the right-angle drive I was seeking, since those seem to be trouble prone. I will now seek the Toyota Angle Speed-O-Dapter shown with the parts number. Thanks very much to both respondents. I'll mention that I have been using a GPS to get an accurate speed reading in my car, but finding a practical mounting spot has been a problem. Since it appeared today that my GPS has failed, that problem seems have taken care of itself.
Look for a hairline radial fracture on either of the two gears--I've seen both plastic and pressed fiber--that are driven directly by the large worm gear driven by the cable. The crack can be just enough to bind the worm gear for a split second, and cause a bounce of the needle.
Rob Glasgow
Bob, thank you for your comment about the rhymtic fluctuations being caused by internal problems. That describes my issue perfectly. I’ll take it apart and see if I can find the cracks.
Rob, Before you tear into your speedo let me clarify: By 'rhythmic,' I mean you will be going along steady at, say 60MPH. Your needle will suddenly jump 5-10MPH, then drop back to 60, and repeat this cycle at a consistent time interval, say 3-5 seconds.
R
RDKeysor
Bronze
My speedo needle just rocks back and forth around the actual car speed. I have (had) a GPS installed that gave me the true speed. Thanks.
R
RDKeysor
Bronze
I have tried to search for the Toyota Angle Speed-O-Adapter, part no 83770-22100, on line. However the parts sellers sensibly want to know the model and year of your car. All I know is that I have W-series Toyota five-speed (I probably have a number buried in my notes back when I had the gearbox exposed). This part model number was graciously supplied by an earlier respondent and is an alternative to a right-angle-drive.
red57
I have no idea why a dealer would ask for the model/year of the application when you give them a part number but I just goggled "Toyota part # 83770-22100" and saw several listings (from Toyota dealers to eBay sellers) with prices ranging from $81 to $118.
roscoe
I suspect that part number would fit most if not all of the W series Toyota boxes. It seems many of the suppliers are in places like the UAE or Japan but here is one in CA. They probably ask what model car it is for because there is a box on their computer screen they want to fill. You should have no problem getting this domestically.
Rob Glasgow
Bob, have you been riding with me? You description is exactly the way my Speedo behaves. At 60 MPH, it will increase 10 MPH and then fall back to 60 MPH about every one or two seconds. The movement is very consistent. Doesn’t happen much at lower speeds.
roscoe
Try a small amount of lubricant on the cable inside the housing. A light grease like Lubriplate or a lithium grease. Clean any old grease off the cable and I'll bet your problem will be gone.
twas_brillig
Regards a place for a GPS: we have a 1962 BJ7 and I've got a Garmin tucked under the dash, with rare-earth magnets JB Welded into the Garmin base and securing it to the heater housing. I've got a power take-off/cigarette plug-in screwed to he wooden piece behind the passenger grab handle on the dash to provide power (as well as a USB charge point). Doug
Michael Oritt
I have experienced what I would call rhythmic variations or "wobble" of the needle below-above any particular speed which I got rid of by carefully modifying the routing of the cable to avoid sharp bends. I always attributed it to the cable's winding up due to friction.
R
RDKeysor
Bronze
I have experimented a bit, including using two different cable lengths in an effort to get rid of the needled bounce. I drilled a hole in the transmission housing in part of this effort, which also made it easier to fiddle the cable because I didn't have to remove the tranny cover. One suggestion I tried that failed was to back off the attaching ring on the back of the speedometer with thought that the cable ws too snug. I think I am currently using bike lithium grease on both my speedo and tach cables. I notice the latter tends exaggerate engine rpm until the car has run a mile or two, suggesting that maybe my lubricant isn't perfect.
Old news, but bears repeating: There is a copper washer used as a spacer between the angle drive an the O/D housing (there's a BMC TSB regarding it, but I can't locate it offhand):
I favor silicone spray lubricant for the cable; it attracts less dust. I clean the cables using a suitable solvent before installation.
J Smitty Toyota Conversion Austin Healey 7
Michael Oritt Pilot Bearing Adapter for Smitty's 5-Speed Kit Austin Healey 3
Michael Oritt Smitty's Five-Speed Manual Austin Healey 1
HealeyBN7 Smitty Austin Healey 4
K Speedometer Drive Gear Issue w/ Smitty/Delaney Tx Conversion Austin Healey 16
S Smitty trans Master cylinder Austin Healey 21
J "Smitty" 5 Speed Clutch Issue Austin Healey 17
J Smitty clutch disc Austin Healey 13
R Smitty Speedometer Cable Fix Austin Healey 1
richberman Smitty Conversion Austin Healey 19
T Pete Delaney/Smitty's 5 Speed - Cost & Description Austin Healey 0
Lin Smitty Conversion -Throw Out Bearing and Pivot Arm Austin Healey 3
CharlieCarpenter Smitty's Healey 5-Speed info??? Austin Healey 13
bighly Smitty Conversion Photos now posted Austin Healey 5
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
G Toyota Wiper Blade Inserts - Cheaper Option Other Cars 3
Michael Oritt Difficult-Shifting Toyota Five-Speed Austin Healey 17
D 1.8 2007 Toyota Avensis Clutch & Flywheel Torque Settings? Other Cars 0
Cappy Toyota 5-Speed Austin Healey 3
Cappy Toyota 5 Speed transmission Austin Healey 4
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
HealeyRick Toyota 5 Speed - Truck or Supra? Austin Healey 16
Michael Oritt Toyota 5-speed shifter bushing Austin Healey 7
Lin Toyota 5-speed bell housing drain hole Austin Healey 14
T Toyota 6 cylinder eng & trans in a BJ7 Austin Healey 0
B TR2/3/3A Mounting Toyota Brake Calipers on my TR3 Triumph 5
Michael Oritt Toyota 5-speed Problem Austin Healey 28
J TR6 Toyota Transmission conversion Triumph 8
Patrick67BJ8 Toyota 5-Speed - Followup of problems. Austin Healey 5
T HP Impact of a Toyota transmission, or a header/2" exhaust ??? Austin Healey 16
S '81 Toyota Celica Other Cars 8
B Propshaft length - Toyota 5 speed conversion Austin Healey 2
aeronca65t One less Toyota 2000 GT Other Cars 5
B Clutch release arm / fork gaiter ; Toyota 5 speed conversion Austin Healey 2
DanLewis Toyota T50 5-speed conversion ?? Spridgets 5
glemon TR6 Toyota Caliper Conversion Triumph 28
2wrench TR6 Do the HVDA [Toyota overdrive conversion] or repair my existing J Overdrive? Triumph 29
aeronca65t Toyota 2000 GT Spotted 9
steveg Front Toyota disc conversion now complete - photo essay Austin Healey 0
steveg First drive - Toyota 4-piston Disc Brake conversion Austin Healey 5
tinman58 TR2/3/3A Toyota brakes on a TR3? Triumph 8
Patrick67BJ8 Toyota 5-Speed slides out of 5th gear Austin Healey 19
T Question I should know - which rotor for Toyota Triumph 9
Sherlock The ultimate Toyota Land Cruiser? Plus a Jeep too Other Cars 3
T BN1 Toyota Gearbox Austin Healey 4
G TR6 TR6 caliper question [Toyota 4 piston?] Triumph 2
H TR6 Toyota Truck calipers on a TR6 WOW Triumph 31
T TR2/3/3A Toyota calipers on a TR3 Triumph 11
T TR2/3/3A TR3 [Toyota] trans question Triumph 5
4 Another Toyota Twink Spridgets 13
