hondo402000
I have read a lot of info on the dreaded thrust washers on TR6's and my question is, should you replace the thrust washers periodically? Just to be sure that they dont wear and fall out and do damage? I purchased a std and .005 over size set from TRF, I think my oil pan gasket needs to be replace and I figured since I had the pan off might as well replace the thrust washers too... thoughts are welcomed, I have a lot of free time
