Wheel Bearings and Thrust Label
Jim_Gruber
OK so I've got some real NOS Wheel bearings and they are labeled with the thrust side. I kept the handy dandy blueline drawing from several weeks ago but who has the simple answer on which way they go in when one side is labeled thrust.
Jim_Gruber
Jim_Gruber
Existing bearings were mounted with thrust lable facing towards one another. Need to confirm if that is indeed correct
According to THIS it depends on where the bearing is marked. if marked on the outer race- then that side faces the inside. If marked on the inner race then that mark faces the outside. No marking then the thicker side of the outer race faces in.
Ez peazy....ya ?
Jim_Gruber
Jim_Gruber
I knew I'd seen that in the last week. OK so both of mine have thrust lableed on the outer race so both face inwards pointing at one another. Thanks.
Jim_Gruber
Jim_Gruber
@$##@@~!%32-313412-34!!!!!! Frickety Frack and curse words that will get me banned by Basil. Got all done, dropped the car off of jack stands and went to tighten lug nuts. Was tightening with 16" breaker bar ratchet and did not over ly tighten. Was snugging up prior to putting torque wrench on the lug nut to 45 lbs. Got PS Complete, went around to DS and at this point was anxious to go out and drive Bugsy. One litle bit of extra pull, almost tight, and SNAP!!!!!!!
Broke off a lug nut and of course everyone stocks 3/8" x 24 wheel studs. Bugsy is down for the count until I can find another 3/8" x 24 Wheel Stud. BTW I did find out Polaris ATV's utilize a 3/8" x 24 wheel stud. Put that in your useful bits of trivia information for future reference when you break a wheel stud and parts from the usual suspects are days away by mail.
I've got to go rumage in my big box of LBC nuts and bolts and see if there is a wheel stud and a nut in there in there. It is a box of all sorts of junk but otherwise I'm off of the road until tomorrow or maybe later in local LBC shop does not have anything available.
RE Wheel Bearing replacement. Lessons Learned
Removing old bearings: very simple, but wheel hub on top of Workmate and clamped between jaws. Sprayed with Brake Cleaner so I could see what was underneath. In a minute or two slots in the hub were very apparent. Found the biggest screwdriver in my toolbox and my 5 lb persuader. Alternated slots, carefully lined up screwdriver and with fairly gentle taps was able to drive out first the inner race, ball bearings all over the floor, more cleaning with brake cleaner, and then the outer race with just a few taps. Inner spacer dropped out, flipped over the hub and repeated the process. Second hub took like 2 minutes to complete.
Reinstalling bearings: If one side is labelled thrust, that side points towards the other bearing labelled thrust. If not a diagram posted on this list in the last 2-3 days shows another methods for identifying the thrust side. A 1 5/16" socket is perfect for installing the smaller bearing and the outer race turned over was perfect for installing the inner bearing. I used a small brass hammer to tap the socket / outer race.
I found no need to cut the outer race as Peter C. suggested to use as an installation tool. The race is tapered and the taper is enough to get the bearing in place and not get stuck. And Peter C., believe me I tried, not sure what those bearings are made of, but they resisted all attempts to even nick the edge with either my band saw or a hacksaw in the vise.
Reinstaling calipers - Make sure the metal tab on the strap that goes between the caliper bolts is peened over. That is your lockwasher, to keep the calipers attached to the car. I found PS caliper bolts really, really, loose as tab was not properly peened over. A safety lesson to all. I know someone here on the list had a caliper fall off recently. This is an important Spring safety tip. When lubing everyhing up there make sure calipers are properly tightened.
Wheel Stud Replacement - unscrew 4 bolts holding hub to rotor, place hub in vise and tighten. Place Center Punch in the middle if broken wheel stud and smack with 5 lb persuader. 2-3 smacks will easily drive out wheel stud.
Time to go out and rummage in the3 garage and see if I can find a wheel stud and nut.
re Cutting bearings
about the only thing i know of that will cut thru the hardened races of a wheel bearing is an abrasive cut off wheel. I think the only thing one can do with hacksaw is strip the teeth off it when you try to use one.
mark
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
Donald1107 TR2/3/3A Wheel bearings Triumph 8
algot1901 HELP with wheel bearings Other British Cars 1
Z 3000 Front Wheel Bearings Austin Healey 3
FlyingCat Spitfire Wheel Bearings Triumph 3
R General Tech Wheel bearings Triumph 3
R Wheel bearings Austin Healey 5
Jim_Gruber New MOSS Tapered Front Wheel Bearings - WTH are the instructions Spridgets 16
N Wheel bearings?? Spridgets 4
N Front wheel bearings?? Spridgets 8
pan Front wheel bearings [BN1] Austin Healey 6
M BN1 front wheel bearings Austin Healey 5
C TR2/3/3A Front wheel bearings Triumph 8
Jim_Gruber New Wheel Bearings Question Spridgets 9
T TR2/3/3A Front wheel bearings direction and torque Triumph 1
Jim_Gruber Removing front wheel bearings from hub Spridgets 6
steveg Shimmed rear wheel bearings Austin Healey 13
mgbmedic TR2/3/3A Modern Seal for Front Wheel Bearings TR3 Triumph 8
sparkydave Groaning noise - wheel bearings? Spridgets 5
G MGB Front Wheel Bearings MG 2
P Bugeye Front Wheel Bearings? Spridgets 1
Morris Front wheel bearings Spridgets 9
N Front Wheel Bearings?? Spridgets 4
Rut Front wheel bearings [again] Spridgets 12
R TR 3b front wheel bearings Triumph 5
D Front wheel bearings Austin Healey 48
P front wheel bearings for 79 midget? Spridgets 4
Jer re-packing front wheel bearings Spridgets 3
tomshobby front wheel bearings Spridgets 13
Tabcon Rear wheel bearings- GET OUT! Triumph 7
N TR6 How to check TR6 front wheel bearings Triumph 1
58Custom Any tricks to changing front wheel bearings? Spridgets 7
Atrus INeed opinions/experience - front wheel bearings Spridgets 7
I TR6 TR6 - how to pack front wheel bearings? Triumph 8
W Front Wheel Bearings Austin Healey 3
vping 1991 Ford Ranger Wheel Bearings help needed Other Cars 0
K TR2/3/3A TR3 front wheel bearings [again] Triumph 3
RickB T-Series 70 BGT - Brakes, wheel bearings, etc MG 9
T Front Wheel Bearings Triumph 26
T TR6 tr6 front wheel bearings Triumph 15
philman Saab 9000 Wheel Bearings Other Cars 6
M Wheel Bearings Triumph 6
M Wheel bearings again Triumph 10
MGFever Upgraded Front Wheel bearings Spridgets 8
T "How To" front wheel bearings Triumph 18
Luke_Healey Fun with wheel bearings... Spridgets 14
J Rear Wheel Bearings Austin Healey 3
eejay56 Spitfire Spitfire wheel bearings Triumph 9
H Bugeye Wheel Bearings - Question Spridgets 7
prb51 Front wheel bearings Triumph 13
