davidk
I am planning to install a hardened thrust washer from Scott Helms. I have two other new thrust washers from two sources and need to know if one is better than the other. (it will be installed on the non-load side). One is from the Roadster Factory and is marked "CTW 2171, it has a copper looking finish on the pressure side. The other has a "G" inside a square box followed by S2021S. It doesn't appear to have any coating. Does anyone know if either one is better than the other. Thanks, David K.
