Speedhut [or alternative] gauges for a BJ7
twas_brillig
We've replaced the o/d transmission with a Toyota 5 speed and the 3.91 (?) diff with a 3.54 Lempert set and wider 72 spoke rims with 185/70 tyres - which means trying to get the speedometer to communicate accurately with this combination.
A number of folks have mentioned Speedhut gauges, and potentially their GPS speedo. Can anyone suggest the specific version that would work (and look stock) in a 1962 BJ7 with black on white gauges (if memory serves - it's been nearly two years)?
Thanks, Doug
Hi Doug,
When I built my Nasty Boy I really tried to keep it stock looking, including all the gauges. With a Ford T5Z transmission and Lempert 3.54 gears, making everything play together was problematical. I looked at the Speedhut gauges, but they couldn't match the stock off-white gauge face and the odometer reading would be digital rather than analog. While on another forum I saw a post about a new GPS driven stand alone device that would hook up to the stock speedo and provide accurate speed readings. I was accepted as a beta tester of the Classic Speed® https://www.classicautoinnovations.com/classic and its allowed me to keep my stock speedo. It's an easy installation and the only exterior sign it's there is a small 1.25" square black plastic antenna that I've tucked away in the corner of the dash top. (Full disclosure, I was given a free unit as a beta tester).
i am also putting speedhut gauges in my bn6 two seater with sbc and aod transmission. i chose white on black faces with blue led backlight. the high beam and turn signal indicators are in the tachometer. i use the healey turn signal light for the alternator charge indicator. using a dual gauge gps speedometer allows me necessary instumentation without hanging gauges below the dash or cutting additional holes. also the fuel gauge is adjustable for the healey tank unit and has a low fuel light as well. speedhut has lots of combinations of fonts, colors, sizes and styles and they have a lifetime warranty..
I also went to Speedhut, ordered the GPS unit black dial with white numbers and white backlight to match the XJ6 Tach I installed as well to deal with pertronix and later engine/distributor. Easy to install and works well.
Thanks, Doug
I have recently had the tacho on my BJ8 converted to a stepper motor drive (as used on modern instruments). No more adjustments and always spot on.
Also speedo converted to digital stepper motor drive; this was rebuilt with exact same face format as original but small LCD at bottom above high beam indicator. The old trip recorder out.
For pusle transducer you simply cut existing cable and install. Thus you can program to accommodate any tire/rear end ratio. No GPS problems with tunnels and landscape issues. Plan to use the MPH but scaled in K's for driving in Canada.
Done by Speedy Cables in Wales.
rg
dklawson Speedhut GPS Speedometers Spridgets 7
Jim_Gruber Speedhut Gauges on sale 15% Labor Day Sale Spridgets 0
Jim_Gruber Need your ideas on a How To Do it - SpeedHut Gauge Install Spridgets 11
Jim_Gruber Another Christmas Present for Bugsy - Speedhut Gauges Spridgets 8
Jim_Gruber Speedhut Gauges- And IGN Warning Lamp Spridgets 16
Jim_Gruber BE Gauges and Speedhut - Is it a 3 3/8" Gauge???? now 20% off Black Friday Sale Spridgets 10
58Custom Can someone share their 3-3/8 Speedhut GPS speedometer face artwork? Spridgets 0
Jim_Gruber Speedhut Gauges Spridgets 12
johntennyson Speedhut Electric Speedometer! Spridgets 7
B speedhut speedo & tach....how did you fit them? MG 2
S Alternative Parts Suppliers Austin Healey 7
3798j Hydrogen...There is an Alternative Other Cars 10
red57 Alternative Healey Austin Healey 2
C Alternative to Moss's BMC Green Engine Paint Austin Healey 10
cpbol Best alternative option to sleeved thermostat? Austin Healey 9
Michael Oritt Interesting audio alternative Austin Healey 2
Marla TR4/4A Alternative system... Triumph 8
Got_All_4 TR2/3/3A Top of steering tube looking for alternative to felt Triumph 10
JimTR4 TR4/4A Alternative spare wheel Triumph 2
B Boot trunk seal alternative advice ? Austin Healey 15
HealeyRick Alternative Sound Systems Restoration & Tools 2
C Alternative Distributor Cap Austin Healey 3
D Cheap sure-shot alternative Spridgets 0
T TR6 TR6 - alternative linkage design? Triumph 4
RAC68 Alternative Remote Brake Booster Austin Healey 3
coj Alternative fuel pumps Austin Healey 19
D Alternative engine/transmission compatibility Spridgets 72
Jim_Gruber Brake Master from Alternative Sources Spridgets 10
BobbyD TR6 TR6 and other TRs - Brake Light Switch Alternative Triumph 7
rkep01 Chrome alternative Spridgets 29
Johnny Here's a few alternative colors for AH.. Austin Healey 0
D Alternative Seats Spridgets 5
Coyote1 TR6 74 TR6 Front Turn Signal Alternative Triumph 9
R GT6 Facet Fuel Pump Alternative [GT6] Triumph 4
Jim_Gruber Alternative Tranny Discussion Spridgets 7
The_architect Bugeye heater cable alternative Spridgets 26
JPSmit Dielectric Grease alternative Restoration & Tools 7
Westfield_XI Alternative coil for MegaJolt/Squirt applications Spridgets 6
UmmYeahOk Anyone Know of a Custom Auto Sound Alternative? Triumph 29
T Heater outlet seal alternative MG 3
R POR-15 alternative Triumph 25
SherpaPilot Slave Cylinder Plastic Pipe Alternative? Triumph 15
Dadandson Starter Solenoid Alternative Spridgets 3
Timd Front end rebuild + A-arm replacement alternative Spridgets 6
BritCarFan Mini alternator alternative? British Motor Corp 1
J Peal and stick stickers, alternative Triumph 7
A Grant steering wheel adapter and/or alternative?? Triumph 2
G alternative power MG 15
T Alternative wheels Triumph 12
R Alternative Fuel Pumps for a 420 Jaguar 10
