BE Gauges and Speedhut - Is it a 3 3/8" Gauge???? now 20% off Black Friday Sale
Jim_Gruber
Please Correct me if I am wrong - Opening for Speedo and Tach in a BE takes a 3 3/8" Gauge.
Reason being SpeedHut just announced a 20% off Black Friday sale starting this evening.
Can someone please confirm for me?
Tis the time for another Christmas Present for Bugsy - GPS Speedo and Matching Tach.
For anyone who has ordered SpeedHut Gauges. What options did you go for. Thinking Center Disc to match the original
look 0-100
High Beam on Speedo, Can Tach accommodate a Generator / Alternator Lamp Low Voltage
And if I add a Generator / Alternator Lamp do I still need an exciter bulb in the circuit if I go to an Alternator - Negative Ground of course.
58Custom
Re: BE Gauges and Speedhut - Is it a 3 3/8" Gauge???? now 20% off Black Friday Sale
For a pillow dash car the 3-3/8 gauge is the one you want. You will have to enlarge the opening about 1/4 inch or so with Dremel or air grinder and that means controlling the dust. I hid the little antenna under the carpet on the panel over the diff in front of the trunk divider. Works great. I used the turn signal indicators because the MG ones are often hidden by the steering wheel.
This is the one I ordered. It looks enough like the Smiths to look like it belongs. The 140MPH is just for looks.
GR338-GPS-02T
3-3/8" GPS Speedometer Gauge 140mph (w/ turn signal and high beam)
  • Colors: Day - Black dial // White font
    Night - Numbers White Glow
  • Font Style: GT
  • Tick Style: standard
  • Pointer: Chrome Blade White (Glows White)
  • Bezel: Chrome Smoothie
  • Window: Flat
As for the alt, I have found when using three wire internally regulated alts that one must retain the incandescent charge indicator light, otherwise the alt will not charge. A 530 ohm 2 watt resistor may be sufficient as a substitute.
Jim_Gruber
Jim_Gruber
Thanks but .I need the answer for a Bugeye Dash. Glad I asked. ok time to go and pull the speedo and actually measure. I could always wire up the BE turn signal indicator as the trigger for the alternator but then I may get into changing the flasher unit. Someone has been down this road before.
Rhodyspit75
The hole for the Bugeye speedo is 3 7/8".
Jim_Gruber
Jim_Gruber
Thank You Sir, you stopped me from taking time on Turkey Day to tear the dash apart to measure. So the next question becomes a SpeedHut 4" Speedo and Tach take a X? Sized hole to install. Time to do some research.
John Kuzman
Hey Jim -
I installed 4" VDO gauges in one of mine. I know that Dremel is your friend. It takes very little to put the 4" in the dash. Happy Thanksgiving!!!
Jim_Gruber
Jim_Gruber
Thanks John. Hope you are warm down South. Tampa bound for a week beginning 12/08 for a week.
John Kuzman
Jim,
I am about 2 to 2 1/2 hours south on I-75 from Tampa. You have my email. Send me a message. Let me know if you are coming down for business or chill out, or a combination. I might make the run up. I can run Route 41 up with the Bugeye or bring American Thunder/aka '69 Corvette.
Jim_Gruber
Jim_Gruber
Placed my order for Tach and Speedo this AM. They are on Vacation Today but added a few options including adding Turn Signal and High Beam on Speedo as well as Ign Lamp on the Tach, and yes I know I still need a regular bulb I the circuit, will mount under the dash someplace, to activate the Alternator. Asked if to was possible to add AH Wings Logo to gauge. Would be a real small font, will need to see artwork proofs from SpeedHut before I give approval. BTW, Austin Healey Logos are available. Google Austin Healy Logo and several sources including one at MOSS Motors will allow you to download the .jpg file.
Jim_Gruber
Jim_Gruber
View attachment 46018Here is the look I am going for. Steering Wheel on Bugsy has slots not holes but this looks to me to be pretty good substitute for OEM, Simple and clean. GPS Antenna will mount magnetically on dash behind the mirror or as Blue Max did it can go on the back of the dash mounted mirror. Anyone looking for a Jaeger 0-8k Cable Driven Tach? Nice tach available. 4" Hole. Price is right.
Jim_Gruber Speedhut Gauges on sale 15% Labor Day Sale Spridgets 0
Jim_Gruber Another Christmas Present for Bugsy - Speedhut Gauges Spridgets 8
Jim_Gruber Speedhut Gauges- And IGN Warning Lamp Spridgets 16
T Speedhut [or alternative] gauges for a BJ7 Austin Healey 4
Jim_Gruber Speedhut Gauges Spridgets 12
waltesefalcon NA Miata gauges Other Cars 16
A TR6 Changing bulbs in gauges Triumph 27
Taftster MGB Electric Gauges Read High, Any guesses? MG 5
J For Sale 1965 TR4 + TR3 Parts - floors, gauges, misc. Triumph Classifieds 14
D Possible Mini Gauges? British Motor Corp 6
Pythias Bugeye [style] gauges in a Box Sprite? Spridgets 13
E Trying to ID some old classic car gauges Restoration & Tools 2
Jim_Gruber Source for Smiths Gauges in UK I believe Spridgets 7
P For Sale O-rings for Smith and Jaeger gauges. Other British Classifieds 2
S TR2/3/3A rubber O rings that go around the gauges Triumph 5
P Wanted AH 100-4 Gauges Austin Healey Classifieds 0
T General TR Request pictures of TR3B & TR4 electric temperature gauges Triumph 15
P AH 100-4 Gauges Austin Healey 0
K For Sale MG Midget Dashboard with Gauges Spridgets Classified 3
K TR2/3/3A Temperature Gauges Again Triumph 5
S TR4/4A procedure for installing gauges etc Triumph 0
HighAltitudeTR3 TR2/3/3A Gauges...? Triumph 2
mgedit TR2/3/3A O-Rings for TR3 Gauges Triumph 9
K TR2/3/3A Gauges held in by "knurled Knobs"?...always losing them. Triumph 10
M rebuilt gauges Spridgets 10
jfarris TR2/3/3A TR3 gauge panel and nuts on gauges Triumph 5
RJS TR4/4A Electrical Question - brake lights, fuel/gas gauges, turn signals failed Triumph 9
R TR2/3/3A Gauges for tr2 Triumph 3
K TR2/3/3A TR4A Gauges in a TR3A? Triumph 13
drooartz Cleaning out the parts: gauges, lights, console Spridgets 4
Zitch TR4/4A No dash lights! Or any of the gauges. Triumph 11
DanLewis Illuminating gauges with Electroluminescent tape Spridgets 24
Got_All_4 Wedge Speedo/temp gauges TR7 Triumph 7
B '93 Voyager gauges won't work?? Other Cars 9
D Gauges Spridgets 15
Patrick67BJ8 Additional Gauges to a BJ8 Dashboard Austin Healey 6
T Nissonger info on rebuilding gauges Spridgets 4
M Chart for wire gauges Triumph 9
B Fluctuating Gauges 68 MGB FORUM Navigation Questions 0
B MGB Fluctuating Gauges 68 MGB MG 5
BugeyeNJ58 New gauges in Dashboard where radio goes... Spridgets 5
abarth69 Wanted Fuel and Oil /water gauges for BN1 Austin Healey 3
HerronScott TR4/4A Early TR4 gauges on Phoenix Craigslist Triumph 2
Andrew Mace Wedge TR7 fuel and temp. gauges not working Triumph 28
HerronScott Why convex/curved glass for gauges? Triumph 11
K Temp gauges on brit race cars? Racing 4
pjsmetana Gauges - 4 & 5 of 7 complete [pics] Triumph 0
pjsmetana Gauges - 3 of 7 complete [pics] Triumph 0
pjsmetana Gauges - 2 of 7 complete [pics] Triumph 10
G Gauges dead after wash Spridgets 6
