Series II E-Type tire size
DonJ
It's time to start shopping for tires. Originals were 185R15 (26.5" diameter / 7.28" wide). Right now I just cannot justify the $380/tire price I am seeing for that size. What is the most appropriate modern size to use? It looks to me like 195/70R15 ( 25.8 / 7.68) or 205/70R15 (26.3 / 8.07) are the most likely. The 205 is the closer diameter but I have read going to a wider tire can affect steering and handling. Would adding 3/4" width really have any effect?
Thanks
dj
Geo Hahn
Not sure what you're looking at that is $380 per - but many (including me) think it is hard to beat the Vredestein Sprint Classics in 185/15. Available from many sources though I think it is a Coker tire wherever you get them from:
Summit for $173 @ -- https://www.summitracing.com/search...dMatch&SortOrder=Ascending&keyword=vredestein
I bought from Euro-Tire -- https://www.eurotire.com/ -- they will email you the current price.
Some fit wider tires but investigate carefully as there can be clearance issues in the rear - think about how far out you have to pull a rear tire to clear the splined hub.
DonJ
Thanks for the response. While looking around on the net for tires I found 185HR15 Dunlops for $370 and 185VR15 Pirellis (which I had years ago) for $389. Not familiar with Vredestein but will certainly follow up on your suggestion. As far as rear clearance I don't think the extra 3/4" is an issue because this car came with steel wheels, not wires, but I will check. Thanks again.
Geo Hahn
Okay - steel/disc wheels to give you more options. Some with wider tires also reverse the rubber buffer above the rear axle (so it leans in) to get a bit more clearance there.
I personally like the looks and handling of the original 'skinny' tires:
One thing I'll note. At one point I had 205s on my series 1. Mostly wasn't a problem but I found that if I hit a bump or otherwise cause the suspension to flex while turning the front tires could grab at the back of the wheel well and bend the sheet metal. This was in the back of the well on the side I was turning towards. So in some circumstances wider in the front was an issue, never a problem in the back.
DonJ
Well, I have been to Coker, Summitracing, Universal, Lucas Classic etc and there does not appear to be any Vredestein 185R15 in the US. I have gotten delivery estimates of "We don't know" to "it will be several months" to "due to production issues these will not be available until mid-2017". So it looks like I will just try to find some 185/70R15.
Geo Hahn
Dang - that is a shame. If you have not done so, you may want to look at one of the online 'tire calculators' to see how much lower your E-Type will be before going with the 185/70.
DonJ
Funny, I was just going to ask what anyone knew about the Universal brand. I did locate some in a 185HR15, but not familiar with the brand.
Geo Hahn, thanks for all your input.
Administrator
Boss
The Vredestein's are what I have put on my E-Type (with new SS Dayton wires). They look just right!
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
M E-type series 1 plastic dash vents Jaguar 1
Basil About to re-install my fuel tank Series I E-Type Jaguar 6
M Photos Needed of Series III E-Type Engine Oil Filter Clearance at Exhaust Manifold Jaguar 1
Q Series 1 E Type Clutch Jaguar 2
D Series III E-Type Overider Rubber Installation Jaguar 2
H Joan Baez flat floor series I e-type roadster: what did the authorities dump it for? Jaguar 0
Simmo Series 3 E Type Brake Bleeding Jaguar 2
J Question about Series III XJ6 Motor in E Type? Jaguar 2
krswen Anybody own Series 1 E-type coupe 1E 32257? Jaguar 2
weewillie Red series 1 or 2 E type Spotted 0
glemon Series 1.5-2 E type, flat towed Spotted 0
glemon Series I E type project Jaguar 17
HEALEYJAG series 2 E-type eyebrow chrome "clips" Jaguar 0
B Series 1 E-Type fuel pump question Jaguar 2
S E-Type 4.2 Series II Performance Exhaust Jaguar 1
jjbunn E-type Series 2 PRNDL shifter ID plate and parts Jaguar 0
rovernut 1970 series 2 e type serial number location Jaguar 6
T Series 2 E-Type Diff Oil Leak... Jaguar 5
Steve Red Series 1&1/2 E-Type.... Spotted 0
Bruce Bowker Series III E Type Jaguar 9
Basil Drool Series I E-Type Jaguar 10
HEALEYJAG series 2 e-type bonnet Jaguar 14
Jim_Newman 4.2 series 1 e-type throwing coolant Jaguar 6
HEALEYJAG e-type series two oil filter Jaguar 6
Jagboy69 E-type Series II Power Steering Pump Jaguar 0
M Looking for a E Type Series III Bell Housing Jaguar 1
S Performance Exhaust for E-Type 4.2 Series II Jaguar 3
C Series II E Type Clock Battery Jaguar 2
Rick60 E-Type Series 3 V12 distributor Jaguar 5
S E-Type Series II OTS Exhaust Jaguar 0
S E-Type Series II OTS Sound System Upgrade Jaguar 0
D Series 2 E-Type won't rev. Jaguar 6
B 69 Series II E-type Hardtop window Jaguar 0
S Bouncing Tach on Series III E-Type Jaguar 4
R Radiator -Series 1 E-Type Jaguar 0
L E-Type Series II vacuum connections Jaguar 0
G Series III E-Type problem to look out for Jaguar 1
AngliaGT Jeep J Series Pickups Spotted 0
B Land Rover Series 3 Wiring Diagrams Rover / Land Rover 0
sim A-series Engine Block Search Spridgets 2
Deanrobert Xke series lll cooling issues Jaguar 5
zoohow TR2/3/3A lights in series Triumph 2
LD-Ordie Series II gear lube question Rover / Land Rover 3
PAUL161 T-Series T Series Starters MG 0
PAUL161 T-Series T series tierod ends MG 2
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
A Making an A-series engine stand adaptor fitting Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
