need photo of engine comp. of BE
mightymidget
1958 Bugeye, I spent the day welding up holds drilled in engine compartment over the last half century. need to compare to stock, making sure I did it correct.
can I remove front shocks without any issues. car jacked up or down.
also on the firewall, below bonnet gutter, where the battery is located. There are two bumps in firewall, they are double walled.
maybe 1" wide couple inches long. Can't figure out what they are for, my best guess is battery bumpers. But mine are rusty and need redoing.
I didn't know how important the open space was between the the double walled area.
Boink
Bronze
There are oodles of engine-less photos out here on the ol' interweb, but there is a completed one. :yesnod:
Gerard
JOeyKnapp
The bumps you talk about had to be fixed in mine too. It wasn't double walled, though. It was a single layer.
JOeyKnapp
I love looking at engine pictures, I can't wait until mine is done, I will just sit and stare at it.... :smile:
Here is the backside of the battery bumps..
M
mightymidget
thanks for references. my next project is the dash removal, I guess British call it a dash. then I can see what has been placed behind. battery bumps. thought the material felt light to the finger probably duct tape to keep hot air from going into interior.
thanks again
M
mightymidget
Gerald your display is excellent, if memory is correct the inner fenders have extra holes I thought were factory since they were on both sides
Boink
Bronze
I knew I'd seen that somewhere as well. Those are fantastic reference images, Gerard!
Gerard
Thank you, Gentleman!... :cheers:
Several people contributed to the effort over a period of time.
Lots of other good stuff lurking there as well... :hammer:
JOeyKnapp
Gerard, I am well versed at Photoshop, if you ever need help with anything like that, just let me know...
Gerard
Thanks Joey. I always welcome contributions or ideas for them. Send me an email of some stuff you've done before. I would like to see it.
Thanks!
Thor Need photo of 76 or later Midget engine bay Spridgets 6
T GT6 Need a photo Triumph 2
R TR6 Need Photo of DS Wiring Harness Route '71 TR6 Triumph 0
T TR4/4A my bad- need tr4 shifter photo Triumph 12
R HELP - Jensen Healy - Cam Timing Need Photo Other British Cars 19
M Need photo of leads from distributor to plugs Triumph 17
D TR2/3/3A Need a photo of a TR3A's heater bracket set up Triumph 3
AUSMHLY Need photo of an original BJ8 petrol cap Austin Healey 1
tony barnhill Need Photo of early VIN Plate Spridgets 19
Shealey I need a photo of the washer bottle mounting Spridgets 14
T TR6 Need a TR6 photo Triumph 1
Shealey Need a photo of a unmolested dash. 58/59 bugeye. Spridgets 25
L Need photo/alignment for rocker panel Austin Healey 11
R Need digital photo of grill fittings Austin Healey 5
tr6web TR6 Need advice removing downpipe nuts Triumph 4
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
Madflyer For Sale Triumph GT 6 parting out need something Triumph Classifieds 10
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
tinman58 TR2/3/3A Need super charger!! Triumph 7
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
