TR6 Need a TR6 photo
T
Tinster
Could someone kindly take a photo of the throttle
control arm, at the end of the throttle cross shaft ,
with the gas pedal pushed down full to the floor?
Mine is installed incorrectly and I need a photo to
get me in the ballpark. Throttle control arm photo,
at full wide open throttle, so I can see how close
to the firewall the top edge of the arms is.
thanks,
dale
G
Dale, you know that it is adjustable?
You can set it up to work with the Ratco linkage no matter where the pedal is?
It's a splined adjuster. Set it so it works with *your* setup.
R TR6 Need Photo of DS Wiring Harness Route '71 TR6 Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 5
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
Gliderman8 General TR Need clarification on Triumph Competition Preparation Manual TR250 TR5 TR6 Triumph 4
S TR6 Need wisdom on tr6 brake calipers Triumph 6
Got_All_4 TR6 Need a frame for TR6 Triumph 21
M Tr6 oil cooler - do need a thermostat n Texas? Triumph 3
N TR6 Need a little wiring help with a 74 Tr6 Triumph 6
PeterK General TR Need a handbrake button and rod TR4a-TR6 Triumph 5
C TR6 Need help with a 1969 triumph tr6 Triumph 21
L TR6 need help on long dead TR6 Triumph 16
S TR6 Help! Need help from TR experts with this frustrating TR6 pushrod/rocker/valve issue Triumph 23
Gliderman8 TR6 Need battery info please for TR6 Triumph 4
2wrench TR6 Need help with '74 TR6 speedometer. Triumph 12
I TR6 Need help on 69 TR6 glove box info Triumph 0
I TR6 Need measurement for tr6 kidney pad please Triumph 4
I TR6 TR6 enine running hot - need some adivce Triumph 40
hondo402000 TR6 Need Help on 71 TR6 Overdrive Wiring Triumph 9
hondo402000 TR6 71 TR6 Hazzard Switch[need one] Triumph 8
B TR6 Need a few opinions on parting out/pricing for TR6 Triumph 8
C TR6 Need a TR6 rim Triumph 1
PatGalvin TR6 Need TR6 Brake Caliper Brackets Triumph 15
I TR6 Boring subject, but still need help TR6 trim rings Triumph 6
B TR6 Need guidance on TR6 electrical issue Triumph 7
T TR6 Scary TR6 sill pictures - anyone need yard fill? Triumph 10
T TR6 need a plug for my late model tr6 head Triumph 12
T TR6 Does a TR6 need an engine to chassis ground strap? Triumph 16
amcboy TR6 I need a TR6 part, or dimensions, or swatted. Triumph 2
N TR6 need the carb mounting stud size for 1974 TR6 Triumph 14
V TR6 Need a Transmission cooler for your TR6? Triumph 4
Got_All_4 TR6 Question and need for a 69 TR6 seat Triumph 1
K TR6 tr6 differential - need feedback! Triumph 16
T TR6 need center radio support tr6 Triumph 4
A TR6 Need TR6 shift lever measurement Triumph 4
T TR6 tr6 intake-if i had one-i'd need this soooo bad Triumph 10
I TR6 Need more headlight help, TR6 Triumph 4
F TR6 Need help w/TR6 oil cooler install... Triumph 16
N TR6 Need drawings for Miata seat mounts in a TR6 Triumph 4
DNK TR6 Need help with a TR6 Tunnel lamp Triumph 12
hondo402000 TR6 need a used dash for 71 TR6 Triumph 1
2wrench TR6 Need help removing glass from '74 TR6 windscreen. Triumph 13
C TR6 I need a little help....quick measurment on a TR6 Triumph 2
A TR6 Need clutch hydralic line ideas [TR6] Triumph 24
2wrench TR6 Need help on '74 TR6 windscreen frame removal Triumph 6
T TR6 "Might as well" if you need to pull the TR6 dash Triumph 6
2wrench TR6 Need replacement bulbs ID'd for under dash '74 TR6 Triumph 4
G TR6 Need a part from an early TR6/250 Triumph 9
A TR6 Need a torque setting for rear axle?? [TR6] Triumph 1
N TR6 Need TR6 distributor advance weight spring Triumph 3
G TR6 Need a part for a TR6 Triumph 1
