twigworker
I took a shot of the underside of the shift tower on this TR4 gearbox before I disassembled it, but screwed the picture up and lost it.
Now I need to see exactly where the distance tubes that fit on each shift rail go.
There are one each on the three main rails and another one on the reverse idler shaft.
If you don't have a photo, a description would work...Example:
On the 1/2 rail the tube goes in front (toward the front of the car)of the fork.
Why did I remove the rails? Because they were jambed up with their detente balls and hard goo from shear age. Was it a chore? Yes. Is it going to be a chore to reinstall the rails and detents? I was until I figured out a "country cure". :wink:
Thanks, Jack
Thanks, Jack
