Distributor rotor gone bad more than once.
pkmh
Hello all, quick question...BJ8 - My distributer rotor: Like the two before on past occasions occurring on my previous Healey, sheared away in the area of the rotor underneath where it is notched or only allowing installation to go one way on the distributor cam. Seems to be a common problem, yes? Just was wondering what trick is there as a remedy or preventive measure of this ever happening or as often as it seems, anyway. Or is there something else I am missing in understanding this dilemma?
germanmichel
Hello,
i know this kind of problems from my old TR6 . The Rotor walk away because of bad fitting on the camshaft. I bend a little bit the inner spring plate and glue the rotor on the cam. So you are able to avoid that the rotor can move and crack on the contact points of the distributor cap.
Good luck.
Bye michel-who still work on his healey body
pkmh
pkmh
What kind of glue? Thought of gluing but how would one remove at a later date, besides cutting out?
germanmichel
Hello, I used Pattex 100 % ( I don't know this is available in the US) This glue is flexible and borderline temperature resistant up to 110 degr. But this is only the suspender additional to the Belt.....:glee: The Spring has to realise the friction on the shaft. Remove is possible by pulling force by hand .Bye Michel- who will visite Goodwood this Year :glee::glee:
PKPoole TR2/3/3A Distributor Rotor Failure Triumph 3
G TR4/4A tr 4a distributor rotor Triumph 0
K TR2/3/3A Distributor Cap&Rotor:Who has the best for TR3? Triumph 6
ChrisS Distributor rotor Spridgets 5
R Source for Ferrari 328 distributor cap and rotor Other Cars 7
Michael Oritt Distributor Rotor Explosion Austin Healey 6
Johnski Distributor Rotor Shorting Austin Healey 18
B TR4/4A Some Help with Setting Distributor Triumph 47
C MGB New plug wires and distributor cap MG 10
M Accuspark distributor Spridgets 2
S TR2/3/3A Distributor vacuum advance hook up to the inner plate Triumph 9
K TR2/3/3A Dr Distributor shipping? Triumph 4
E TR6 Rebuilding Distributor Triumph 2
K TR2/3/3A Distributor internal wires? Triumph 5
PAUL161 T-Series My 55 TF Xpeg Distributor MG 2
C Spitfire Mystery wires - Spit, left near distributor Triumph 2
JPSmit Distributor question Spridgets 0
B MGB 42d4/45d4 distributor MG 0
S TR2/3/3A Installing the distributor pedestal. Triumph 3
A TR6 TR6 Distributor cap issue Triumph 4
C MGA Setting a 123 distributor MG 0
K TR2/3/3A A couple of small distributor tech questions..... Triumph 10
vette Distributor Advance Austin Healey 14
S TR2/3/3A tack drive on the distributor must have caused those cuts in the gear Triumph 4
AngliaGT MGB-GT Extremely Dumb Question - Distributor Hose - SOLVED! MG 3
1275GT Wanted 23D4 distributor #40819 Other British Classifieds 0
M TR2/3/3A 25D4 CSI Optimized Distributor Triumph 4
T TR4/4A Why are distributor base plates different, is this a problem? Triumph 7
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
steveg 100-4 Distributor Internal Ground Wire Austin Healey 6
WJKB-TR6 TR6 '73 Distributor Cap Brush Triumph 5
R Distributor: Reassembling BJ8 Engine Austin Healey 5
Lin Jaguar Distributor Cap for Healey Austin Healey 8
T Pertronix distributor install into Austin Healey 100/6 Austin Healey 12
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
K TR2/3/3A Do Lucas distributor points still have the" Lucas logo" on them.... Triumph 4
K TR2/3/3A Aftermarket Distributor Points and Terminal Bush leads? Triumph 1
S For Sale TR3 front nose,trunk & petronix distributor Triumph Classifieds 0
P DM6A Distributor Question Austin Healey 9
A TR2/3/3A A123 distributor Triumph 5
AUSMHLY Distributor cap center pin melted Austin Healey 5
M Mallory Dual point distributor Austin Healey 0
K TR2/3/3A Distributor Caps Triumph 6
Csarneson Source for distributor drive peg? Mystery Part? Austin Healey 8
K TR2/3/3A The Distributor Dwell reading... Triumph 1
W Mallory distributor on '60 BT-7 Austin Healey 4
R TR2/3/3A Establishing distributor shaft end float Triumph 4
