Source for Ferrari 328 distributor cap and rotor
R
RonMacPherson
Anyone know of a source for Ferrari 328 distributor cap and rotors?
This is the V-8 engine with two 4 cyl distributor caps.
My friend has his rotor and caps dying(after 128K miles). And replacement parts(from what we can find) are supero expensive.
Can anyone say 700 dollars?
If anyone knows of a source of cap and rotor for less money, but with comparable quality, please lemme know.
Aloha
He can just send me the car, and I'll buy some new caps for it - hehehehehehe.
bugimike
It is strange that Kenny replied with his picture of an Alfa in his post, because the first thing I thought of was 4 cyl. Alfa parts. I know, years ago that U-joints in a Ferrari were interchangable with Alfa parts at a MUCH more reasonable cost!!! Might be a place to start looking (and also Fiat parts have a fair amount of interchangability too, most Italian ign. parts are of Marelli origins!)! :wink:
my alfa is bosch ignition. After doing a little research lastnight before bed. It appears that $800-$900 is the going rate for a good ferrari shop to replace the caps and rotors for you. However, if it was my Ferrari, I'd just go ahead and have a major service done for about $3000-$4000 which includes most everything you can thing of, including new engine seals. Piece of mind ya know.
R
RonMacPherson
yeah, we just did seals, belts, water pump, gaskets, etc... Fuel system, just gotta get the ignition cleaned up.
Platinum
Marelli or Bosch, Ron? I.D. tag on th' unit(s)? Mebbe there's a cross reference for an Alfa cap... I can't envision 'em bothering to use a totally proprietary cap/rotor.
JPSmit
otherwise google used ferrari parts - lots of links. Even car-part.com has a 308 in its data base
R TR6 Help: Brake Part Source or …. ? Triumph 1
M General TR Source for J Type O/D Solenoid Circlip Triumph 0
Jayplum TR2/3/3A Source for quality parts Triumph 11
B Vacuum Source Austin Healey 4
W Best source for Bugeye front shocks Spridgets 3
B TR6 Source for Carmine Red Triumph 4
steveg TR6 Source for fuel line P-clip Triumph 17
Sarastro TR4/4A Source for good convertible-top snaps Triumph 6
Sarastro TR4/4A Identifying the source of gear noise. Triumph 15
M TR2/3/3A Identifying Rear Axle Leak Source Triumph 12
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Michael Oritt Tenax fastener source needed Austin Healey 6
Csarneson Source for distributor drive peg? Mystery Part? Austin Healey 8
R TR6 Body Parts Source, Upper Midwest Triumph 6
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
Jim_Gruber Source for Smiths Gauges in UK I believe Spridgets 7
crya Current go-to source for VIN/Chassis Repro Plates? Austin Healey 8
RAC68 Source - Metal Clips for securing Convertible Top and/or Seat Covers Austin Healey 11
S Wanted Source for 100 6 right hand remote control door regulator Austin Healey Classifieds 1
S TR2/3/3A source for those little drain hoses Triumph 6
I TR6 Source for Elevator Bolts? Triumph 16
I TR6 Source for license plate light bracket? Triumph 5
steveg Excellent source for info on and rebushing of SU carbs Restoration & Tools 0
MikeAH100M Whitworth Source Austin Healey 8
Jim_Gruber Source for 3" cotter pins for bump rubber on BE Rear axle Spridgets 5
K Healey Blue Paint Source Austin Healey 30
D Body work finishing supplies source. Restoration & Tools 0
Csarneson Source for Distributor Fiber Thrust Washer Austin Healey 3
JPSmit DC Power source thoughts Restoration & Tools 11
B TR2/3/3A Locating source of oil leak Triumph 6
J Half round tube or D tube source ?? Restoration & Tools 2
HealeyDave TR2/3/3A TR3 Dash Cover Source Triumph 9
B New frame candidate or parts source? Austin Healey 12
S Bay Area source for 60 Sprite Roll Bar? Spridgets 6
Jim_Gruber Source for PosiDrive Screws Spridgets 7
R TR2/3/3A Source for rubber seal on A/M side curtains Triumph 4
J TR4/4A TR4A rear wheel cylinder source Triumph 3
I Bigeye transmission source? Spridgets 7
Rut TR4/4A Good interior source Triumph 29
R Source for return spring on Early BN4 locking door handle? Austin Healey 1
Jim_Gruber Source for Small U Bolts on 1/4 Elliptic Springs- Spridgets 11
bighealeysource Source for correct washer for overdrive drain plug Austin Healey 6
Csarneson Source for BN4 2nd Gear Austin Healey 8
CJD TR2/3/3A Source for Horsehair Padding? Triumph 10
Michael Oritt Rear upright casting--source needed Racing 4
I TR6 Under bonnet sticker source Triumph 3
D General TR Front carpet source? Triumph 1
Steve P. Best source for new tappets? Austin Healey 11
I General TR Source for glass mirrors Triumph 5
Patrick67BJ8 "Cover" for Top. Source wanted Austin Healey 6
