Ignition key trouble
Sportsdoc
First click activates the electrical components, but next click will not activate the starter. Can push button on the solenoid and start the car. I suspect I need a new switch. Any ideas?
Either that or you have a bad connection. Can you short the switch ie hotwire to start?
push button can be added but you must have the key on and off normally to activate alt circuit kill circuit and the like.
What I meant by push button was that I can push the button on the solenoid and it will activate the starter. Turning the key switch will not activate the starter.
Dead switch
Broken electrical connection to the solenoid
Dead solenoid
Does the solenoid click when you turn the switch?
If yes, just dirty internal contacts. But I doubt that, because it starts when you push it.
Since it will start with the ignition switch on, then the switch is getting battery power.
See first three suggestions.
Check the white/red wire from the back of the key to the small terminal on the solenoid. Or run a piece of wire to replace it, that will at least tell you whether it's the key or a wiring problem. It could be the solenoid too, it has to be grounded for that white/red wire to engage the contacts.
The solenoid is not grounded at present as I am in the process of making a new bracket. I had to replace the rusted out heater/battery plate and the new plate did not have the solenoid bracket. I was wondering if that could be a problem.
J Ignition Key Malfunction Austin Healey 6
PAUL161 T-Series MGTF Ignition Key MG 7
J Ignition Key Cylinder Removal Austin Healey 3
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
6 1965 Sprite Ignition Key Spridgets 3
G General Tech Have new blank key for TR3 but cannot get it "cut" to fit ignition. Triumph 14
S TR4/4A Ignition switch key position Triumph 2
5 ignition-trunklatch key Austin Healey 3
H Spitfire Triumph starts just fine but Ignition is 'Off' and key is in my wife's purse. Triumph 6
W Bugeye ignition key repalcement Spridgets 2
J TR2/3/3A Ignition key issue Triumph 4
PatGalvin TR5/TR250 TR250 Ignition Key Question Triumph 4
Jeepster Ignition key Austin Healey 12
BugeyeNJ58 Ignition Switch and key Cylinder comes apart! Spridgets 0
V Help: key broken off in ignition! Triumph 18
B T-Series Ignition key switch help ! MG 7
7 Ignition light stays on after key removed. Why? Triumph 19
memphis BJ8 - Leave ignition key on? Austin Healey 5
angelfj1 TR2/3/3A TR3A Ignition Switch - new lock/key Triumph 5
T Ignition key MG 23
G ignition key/lock switch question Spridgets 0
G Removing ignition key/lock switch? Spridgets 5
J ignition key turning, BJ8 Austin Healey 5
H TR6 TR6 Ignition Key Triumph 3
2wrench TR6 No response at key ignition '74 TR6 Triumph 5
O Key in Ignition warning buzzer Triumph 5
1 Stuck at work! Key won't turn in ignition MG 30
TR4 TR4/4A TR4 Won't start using the ignition key !!!!! Triumph 3
TNMGB Hmmm...can't get key out of ignition... MG 11
C Ignition light on/ key off MG 5
Bret Ignition running on after key is removed? MG 8
R Ignition Failure Austin Healey 12
R Bugeye ignition switch Spridgets 2
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
T 100 BN2 Possible Ignition Issue Austin Healey 10
Cokerair TR4/4A Fried Ignition Coil Triumph 18
R Wanted Bugeye ignition switch Spridgets Classified 2
J TR2/3/3A Red ignition light stays on Triumph 7
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
F Hot Ignition Coil Austin Healey 6
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
SherpaPilot TR6 Ignition Switch Question Triumph 13
P TR2/3/3A ignition switch smoking Triumph 12
rgfrey BN4 Ignition/Turn Indicator Light Austin Healey 7
PAUL161 T-Series Points Triggering Electronic Ignition MG 5
W Healey BN1 Ignition Light Austin Healey 8
