Ignition Failure
RDKeysor
Bronze
My '60 BN7 went dead while driving today. Plenty of fuel, the filter bowl was full, and nothing obvious. I think it's an ignition issue and will pull a plug and check for spark. Any other suggestions?
Patrick67BJ8
Good place to start with sparkplug firing.
Check the Battery Shut Off switch to see if the white/black wire is hooked up correctly and not loose and grounding anywhere on the chassis.
NutmegCT
Couple other possibilities:
1. carb jets clogged.
2. engine ground cable loose/corroded
3. loose low-voltage wire on distributor
4. dead condenser and/or coil (coils often "slowly die until useless")
5. generator/alternator failing, or loose wires preventing battery charging, and thus, voltage too low to spark
6. distributor clamp loosened, so distributor has rotated in the socket causing time to be totally "out of whack"
Scargo
Did it stumble/shutter to a stop (usually fuel related) or cut off totally and instantly (usually ignition/electrical related) ?
R
RDKeysor
Bronze
The car was running perfectly and lost power during acceleration at about 25 mph. I had driven about 20 miles at that point. As it died, I tried putting it back into gear for a rolling restart without success. After it came to a stop, it cranked vigorously without any sign of firing. Under the hood the filter bowl appeared to be full. There was plenty of gas. I'm now looking for information on how I can test the electronic ignition system (and as suggested by another forum member, the coil). I might add that AAA managed to leave me stranded for four hours, sending a lift from a town so distant that the driver had no idea where I was. On the plus side, the lift driver was competent and got the car home for me. Now for the confession that may be relevant. I had been working on the car's electrical system for several days, issues with turn signals and the PO's lighting applied to the reflectors above the tail lights. Everything was again functioning. I was aware that it is risky to leave the ignition turned on when the car isn't running. I have two electrical shutdowns on my car, the one in the boot and a breaker under the hood that many in our Healey club installed. Despite constant switching the car off and on to avoid burning out the ignition electronics, I came out one morning and found I had left the car overnight with ignition on. I have driven the car several time since this blunder, but know it could be the origin of the Pertronix ignition--if that the was the cause and want it on the record. At 86 there are signs of slippage.
NutmegCT
you got it - leaving the coil and pertronix energized without running the engine - not good.
At 76, my slippage is growing increasingly problematic!
John Turney
Remove the wire from the coil to the distributor cap at the distributor and see if you get a spark from the coil. If you get a spark from the coil, it would be the distributor cap or rotor. If you don't get a spark from the coil, it may be the coil or Pertronix. Make sure you're getting voltage to the Pertronix.
R
RDKeysor
Bronze
I went to the car in the garage this afternoon intending to turn the engine over for a minute or so to check for fuel on a plug and then grounding the plug on the block to check for spark. You guessed it, about 26 hours after it abruptly quit running, the engine started up promptly and ran perfectly well. I ran it for a couple of minutes at about 1500 rpm and then let it settle into idle about 900 rpm. It usually idles a bit higher despite my efforts to get it under 1000 rpm. Now what? I am a bit apprehensive about driving the car for fear of a repeat episode. I also have to wonder whether it might have started during my four-hour wait for the lift. I don't have a clue but am glad I don't have to buy a new Pertronix ignition kit, that being my wrong guess as having failed. Interested in opinions. Thanks to the forum members and their responses, all of which merited my consideration
BoyRacer
Check your wire connections. If you have any crimp connectors make sure they are tight and have enough strands of wire into the connector. I bought an old Chevy pickup many years ago and it would die after 20 -30 minutes of driving. I changed everything and it kept doing it. Finally, I pulled the wires at a butt connector to the coil and it moved ever so slightly. It was barely hanging on.. As the resistance in the wire strands would build it would heat up lose continuity, and the engine would die.
A Ignition rotor recommendations - odd failure Austin Healey 11
R Bugeye ignition switch Spridgets 2
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
T 100 BN2 Possible Ignition Issue Austin Healey 7
Cokerair TR4/4A Fried Ignition Coil Triumph 18
R Wanted Bugeye ignition switch Spridgets Classified 2
J TR2/3/3A Red ignition light stays on Triumph 7
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
F Hot Ignition Coil Austin Healey 6
J Ignition Key Malfunction Austin Healey 6
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
SherpaPilot TR6 Ignition Switch Question Triumph 13
PAUL161 T-Series MGTF Ignition Key MG 7
P TR2/3/3A ignition switch smoking Triumph 12
rgfrey BN4 Ignition/Turn Indicator Light Austin Healey 7
PAUL161 T-Series Points Triggering Electronic Ignition MG 5
W Healey BN1 Ignition Light Austin Healey 8
C TR6 Ignition Switch for 1972 TR6 Triumph 1
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
E Ignition Timing Austin Healey 14
T TR6 Continuous Starting and Ignition Issues Triumph 6
TRickster6 MGB electronic ignition on '73 MGB MG 1
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
jlaird MGB ignition switch MG 2
algot1901 Electronic Ignition for 1950 Prefect 1172cc Eng Other British Cars 10
Lin Ignition timing question Spridgets 2
H MGB 1980 mgb no power from ignition switch MG 23
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
Lin Crane or Fast XR700 Electronic Ignition Austin Healey 4
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
PAUL161 T-Series MGTF Xpeg Ignition Coil MG 22
M Tachometer not working following ignition upgrade Austin Healey 10
Cappy Ignition Warning Light Austin Healey 6
longbridgehealey Bugeye ignition switch Spridgets 4
J Ignition Key Cylinder Removal Austin Healey 3
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Lin Installation Notes for 1-2-3 Electronic Ignition Austin Healey 1
S Ignition advance weights - how to lube? Austin Healey 5
K TR2/3/3A Ignition Timing? Triumph 11
WJKB-TR6 TR6 '73 Ignition [IGN] Red Light questions. Triumph 6
WJKB-TR6 TR6 Ignition Switch-73TR6 Triumph 5
S 58 Bugeye Ignition/Light Switch Spridgets 1
S 58 Bugeye Ignition/Light Switch FORUM Navigation Questions 4
O Sprite Petronix Electronic Ignition Spridgets 10
