Ignition Key Malfunction
Jerry
Group,
My BJ8 ignition key is getting picky. It turns the car over all the time, but the connection to the coil is not there all the time when the starter is going. I tested this by running a wire from a hot fuse direct to the coil and the car starts quickly that way. I can feel like there is a spot in the key turn where a disconnect is happening to the wire to the coil. Once started and the key is back to the run position, it works fine.
So, can you replace the ignition with the console in place? I really don't want to remove the console if possible.
Jerry
mezy
Run a wire from the start wire on the starter solenoid up to the coil so that when the engine is cranking over there will be power to the coil.
Hangtown Healey
Group,
Jerry
I have changed the switch with the console in place, but then I didn't have any AC to get in the way.
I think you can; I've had to replace a couple O/D switches and don't recall having to remove the console, though it would probably be easier if you did (if you have a radio it will have to come out).
J
Jerry
back to running a wire from the solenoid to the coil. If you do that, once the car is running it will feed power back to the solenoid full time. I think there is a electrical component that would only allow power to run one direction, but I can't remember what it is called?
Just curious if you have a lot of keys and junk pulling on the lock. I have had the ignition cut out with all the stuff on the key ring. Try just the key and one or two other things to lighten the load on the lock. It has been working fine for a year. I bought a new lock housing (I can reuse the lock mech with the new part) and I am just waiting for it to kick out again as I am not excited about removing the console again.
PAUL161 T-Series MGTF Ignition Key MG 7
J Ignition Key Cylinder Removal Austin Healey 3
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
6 1965 Sprite Ignition Key Spridgets 3
G General Tech Have new blank key for TR3 but cannot get it "cut" to fit ignition. Triumph 14
S TR4/4A Ignition switch key position Triumph 2
5 ignition-trunklatch key Austin Healey 3
H Spitfire Triumph starts just fine but Ignition is 'Off' and key is in my wife's purse. Triumph 6
W Bugeye ignition key repalcement Spridgets 2
J TR2/3/3A Ignition key issue Triumph 4
PatGalvin TR5/TR250 TR250 Ignition Key Question Triumph 4
Jeepster Ignition key Austin Healey 12
BugeyeNJ58 Ignition Switch and key Cylinder comes apart! Spridgets 0
V Help: key broken off in ignition! Triumph 18
B T-Series Ignition key switch help ! MG 7
7 Ignition light stays on after key removed. Why? Triumph 19
memphis BJ8 - Leave ignition key on? Austin Healey 5
angelfj1 TR2/3/3A TR3A Ignition Switch - new lock/key Triumph 5
T Ignition key MG 23
G ignition key/lock switch question Spridgets 0
G Removing ignition key/lock switch? Spridgets 5
J ignition key turning, BJ8 Austin Healey 5
H TR6 TR6 Ignition Key Triumph 3
S Ignition key trouble Spridgets 7
2wrench TR6 No response at key ignition '74 TR6 Triumph 5
O Key in Ignition warning buzzer Triumph 5
1 Stuck at work! Key won't turn in ignition MG 30
TR4 TR4/4A TR4 Won't start using the ignition key !!!!! Triumph 3
TNMGB Hmmm...can't get key out of ignition... MG 11
C Ignition light on/ key off MG 5
Bret Ignition running on after key is removed? MG 8
R Ignition Failure Austin Healey 12
R Bugeye ignition switch Spridgets 2
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
T 100 BN2 Possible Ignition Issue Austin Healey 10
Cokerair TR4/4A Fried Ignition Coil Triumph 18
R Wanted Bugeye ignition switch Spridgets Classified 2
J TR2/3/3A Red ignition light stays on Triumph 7
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
F Hot Ignition Coil Austin Healey 6
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
SherpaPilot TR6 Ignition Switch Question Triumph 13
P TR2/3/3A ignition switch smoking Triumph 12
rgfrey BN4 Ignition/Turn Indicator Light Austin Healey 7
PAUL161 T-Series Points Triggering Electronic Ignition MG 5
W Healey BN1 Ignition Light Austin Healey 8
