Spitfire Triumph starts just fine but Ignition is 'Off' and key is in my wife's purse.
Hetkey
Last Spring I bought my wife a 79 Spitfire 1500 that she fell in love with. This winter the battery seemed a little low so I figured I'd throw a tender on it. My wife was at the office with the keys in her purse so I went down to the garage, opened the hood and connected the tender to the battery terminals...lo and behold, the car started right up. I checked the ignition and it is in the 'Off ' position. I'm thinking I have a short somewhere between the key-hole and the exhaust pipe. Before I just start replacing components i was wondering if anyone had any suggestions.
CH
"If you marry a blonde half your age,
be prepared to spend your golden years up to your elbows
in her sports car."
Geo Hahn
When you say "the car started right up..." do you mean the starter cranked the engine? Did you connect directly to the battery posts or to something that looked to be connected to the posts?
I know zip-all about Spitfires but I would start by looking if the solenoid is sticking or if the trigger wire from the ignition switch (possibly white with a red tracer) is hot (12v).
H
Hetkey
I hooked directly to the battery, and battery to Ground. The engine rolled over and started. The thing is, nothing has changed on the car since she drove it error free in the fall. The only difference is that it got cold out. I'm looking at replacing the solenoid (thanks for that) and the coil.
Geo Hahn
Something isn't right but I don't know that I'd rush to swap in new parts without knowing more.
Unless your battery charger is very different from mine - it lacks anything near the power to crank an engine. Rather, something in the connection you made jumpered the starting circuit &/or the ignition circuit and the battery did the starting.
Andrew Mace
My first thought would be to check the key switch for possible sticking. Maybe just put the key in and work the switch a bunch of times, then take it out and see if you can duplicate what happened before. (Or, if you want to start at that switch and do some multimeter or test light testing for live circuits, you could do that as well). Replacing either coil or solenoid would do you no good, as it seems obvious (from the fact the engine started) both are fine.
H
Hetkey
Thanks for the advice everyone. I'll try it with the key and climb in the engine with a multimeter and post back what I find.
CH
JerryVV
Good that it was out of gear or that could have been disastrous. If you try that again be certain it is out of gear.
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
T TR4/4A Triumph TR4A 1965 price Triumph 8
M For Sale 1971 Triumph Tr6 Triumph Classifieds 0
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
Charlypm For Sale 69 Triumph TR6 Racecar Triumph Classifieds 1
J TR4/4A Vintage Triumph Register Build Codes Triumph 6
J SOLD!! Triumph TR 2 TR 3 windshield stanchion mounting plates Triumph Classifieds 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 9
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 1
C For Sale 1963 Triumph TR3b-TCF Triumph Classifieds 5
tr6nitjulius General TR 1/1/2024 in TRIUMPH Triumph 0
pbraun For Sale Triumph TR 250 Project Triumph Classifieds 0
R For Sale FS: Revolution 5 Spoke Wheels (Triumph) Other British Classifieds 4
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
tr6nitjulius General Tech TRfest 9/7-10th 2023 (150+ TRIUMPH Only) Triumph 6
R TR6 Triumph vin tag information Triumph 7
L For Sale British car collection for sale Morris Minors, Triumph Other British Classifieds 0
L For Sale 1961 Triumph Herald Saloon Triumph Classifieds 0
L My 1951 Triumph long ago British Motorbikes 0
tr6nitjulius TR6 TRIUMPH invades Redmond, Or for ATDI 2023 Triumph 4
Hamish Racing General TR At last a New Triumph Triumph 2
Got_All_4 General TR New Triumph Concept Car TR25 Triumph 14
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
XJtom General TR Triumph items of interest Triumph 2
B TR6 Triumph tr6 coolant leak Triumph 4
Gatheringtree TR2/3/3A Billet Pedal Cover Set w/ Triumph logo Triumph 0
D For Sale 1974 triumph spitty davidschab60@gmail.com Triumph Classifieds 0
Gliderman8 General TR Triumph emblem? Triumph 13
D TR2/3/3A Drive your Triumph day photo Triumph 6
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
J For Sale Triumph TR2 or TR3 elbow trim Triumph Classifieds 0
J For Sale Triumph TR3 door, left, for sale Triumph Classifieds 0
S TR2/3/3A Triumph TR3 Tail Light Issue when Headlights and Brakes are On Triumph 15
D For Sale Triumph GT6 for sale (possibly one of the worlds finest examples) Triumph Classifieds 2
S For Sale Triumph TR 2-3 Front Left Fender Triumph Classifieds 2
KVH General Tech Making the Triumph Engine Dolly Triumph 4
P Post-War Other Triumph Herald Engine ID Triumph 2
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tr6nitjulius General TR All TRIUMPH Only Drive In 2022 Triumph 4
D Forum for Triumph TR6 only FORUM Navigation Questions 2
Quackedo TR6 1969 Triumph TR6 Differences Triumph 18
J Wanted WTB Triumph TR3 inner sills Triumph Classifieds 8
