Ignition Warning Light
Cappy
Cappy
I just installed an alternator. When I switch on the battery, the ignition warning light comes on. When I turn on the ignition, it goes off and stays off when I crank car. I thought it should come on when ignition is turned on and go off when engine cranks. Any ideas what is wrong?
vette
Cappy, I will attach two pics of the way I wired my AC Delco, 3-wire alternator in my BJ7 Healey. It has been running this way for about 10 years now. Hope this helps. In the one pic it shows an Amp meter. Skip the amp meter as it will not record accurately as shown. But the #10 red wire must be connected from the main alternator Battery terminal to the solenoid terminal that feeds thru to the battery.
vette
Just a point of clarification about the charge indicator wiring with the 3 wire alternator. You will notice that the indicator light has 2 wires on it that both appear to be coming from a source of voltage. The light will be off when both those wires have the same voltage on them. In other words, when the alternator is not turning the light sees voltage from the ignition switch run terminal when the ignition switch is in the on position. That is battery voltage. But the other wire on the charge indicator light goes to the alternator. When the alternator is not turning and therefore not generating any voltage then this side of the indicator light sees ground thru the alternator and the light lights up. As it should when the key is on but engine not running.
When the alternator starts to turn and therefore generates voltage the both sides of the charge indicator light have the same voltage therefore no difference of potential across the bulb and the light will not light up. Therefore when the alternator is putting out voltage the light goes out because it has the same voltage on both sides of it. Also this arrangement provides an indication of when the alternator is not putting out enough voltage and starting to fail as this light will flicker or come on solid even when the engine is running. Hope this helps.
Cappy
Cappy
Just got back to my light problem. Thanks Darth Vader, for pointing out that two wires from a power source go to light. I found a bad connection on the small wire to alternator. When fixed it works as it should.
T Ignition warning light remains on and headlights come on Austin Healey 8
W Ignition Warning Light Austin Healey 6
M Ignition warning light? Spridgets 14
M Ignition warning light Triumph 22
BillyZ TR6 1976 TR6 Ignition warning light Triumph 17
Kurtis TR4/4A TR4 Ignition Warning Light Triumph 6
O Key in Ignition warning buzzer Triumph 5
R Ignition Failure Austin Healey 12
R Bugeye ignition switch Spridgets 2
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
T 100 BN2 Possible Ignition Issue Austin Healey 10
Cokerair TR4/4A Fried Ignition Coil Triumph 18
R Wanted Bugeye ignition switch Spridgets Classified 2
J TR2/3/3A Red ignition light stays on Triumph 7
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
F Hot Ignition Coil Austin Healey 6
J Ignition Key Malfunction Austin Healey 6
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
SherpaPilot TR6 Ignition Switch Question Triumph 13
PAUL161 T-Series MGTF Ignition Key MG 7
P TR2/3/3A ignition switch smoking Triumph 12
rgfrey BN4 Ignition/Turn Indicator Light Austin Healey 7
PAUL161 T-Series Points Triggering Electronic Ignition MG 5
W Healey BN1 Ignition Light Austin Healey 8
C TR6 Ignition Switch for 1972 TR6 Triumph 1
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
E Ignition Timing Austin Healey 14
T TR6 Continuous Starting and Ignition Issues Triumph 6
TRickster6 MGB electronic ignition on '73 MGB MG 1
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
jlaird MGB ignition switch MG 2
algot1901 Electronic Ignition for 1950 Prefect 1172cc Eng Other British Cars 10
Lin Ignition timing question Spridgets 2
H MGB 1980 mgb no power from ignition switch MG 23
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
Lin Crane or Fast XR700 Electronic Ignition Austin Healey 4
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
PAUL161 T-Series MGTF Xpeg Ignition Coil MG 22
M Tachometer not working following ignition upgrade Austin Healey 10
longbridgehealey Bugeye ignition switch Spridgets 4
J Ignition Key Cylinder Removal Austin Healey 3
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Lin Installation Notes for 1-2-3 Electronic Ignition Austin Healey 1
S Ignition advance weights - how to lube? Austin Healey 5
