Ignition Warning Light
Walker sim
Member
Hi, My BN1 1954 100/4 service manual mentions an 'Ignition Warning Light". I can't find one on my facia & it's not mentioned on the instruments & controls diagram.
My guess is it's not an ignition but a charging indicator but I still can't find it.
Anybody shed light?
vette
Re: Walker sim
Hello Walker, I don't have info on the 4 cyl. cars but here is a drawing of the early 6 cyl cars that might help you. On the early 6 cyl car the light is a small light on the bottom of the tach gauge. It is the charge indicator light. It has a white wire that goes to the ignition switch and a brown/yellow wire that goes to the voltage regulator. Don't know if the 4 cyl cars would be using the same colours but it shouldn't be too hard to find.
Re: Walker sim
Anybody shed light?
Should be on the lower/center part of the tach dial. It basically indicates the electrical power source; if it's lit you're running off the batteries, if not--hopefully--you're running off the dynamo (I believe it's wired in series with the cutoff switch in the regulator). Interestingly, it's recommended that you use a lamp instead of an LED bulb in this application, though I ran an LED for many years/miles with no issues. With an incandescent bulb, if you look close you can see the light fade as the dynamo takes over.
Duane_Rhynard
Anybody shed light?
Some light!:
Cappy Ignition Warning Light Austin Healey 6
T Ignition warning light remains on and headlights come on Austin Healey 8
M Ignition warning light? Spridgets 14
M Ignition warning light Triumph 22
BillyZ TR6 1976 TR6 Ignition warning light Triumph 17
Kurtis TR4/4A TR4 Ignition Warning Light Triumph 6
O Key in Ignition warning buzzer Triumph 5
R Ignition Failure Austin Healey 12
R Bugeye ignition switch Spridgets 2
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
T 100 BN2 Possible Ignition Issue Austin Healey 10
Cokerair TR4/4A Fried Ignition Coil Triumph 18
R Wanted Bugeye ignition switch Spridgets Classified 2
J TR2/3/3A Red ignition light stays on Triumph 7
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
F Hot Ignition Coil Austin Healey 6
J Ignition Key Malfunction Austin Healey 6
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
SherpaPilot TR6 Ignition Switch Question Triumph 13
PAUL161 T-Series MGTF Ignition Key MG 7
P TR2/3/3A ignition switch smoking Triumph 12
rgfrey BN4 Ignition/Turn Indicator Light Austin Healey 7
PAUL161 T-Series Points Triggering Electronic Ignition MG 5
W Healey BN1 Ignition Light Austin Healey 8
C TR6 Ignition Switch for 1972 TR6 Triumph 1
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
E Ignition Timing Austin Healey 14
T TR6 Continuous Starting and Ignition Issues Triumph 6
TRickster6 MGB electronic ignition on '73 MGB MG 1
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
jlaird MGB ignition switch MG 2
algot1901 Electronic Ignition for 1950 Prefect 1172cc Eng Other British Cars 10
Lin Ignition timing question Spridgets 2
H MGB 1980 mgb no power from ignition switch MG 23
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
Lin Crane or Fast XR700 Electronic Ignition Austin Healey 4
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
PAUL161 T-Series MGTF Xpeg Ignition Coil MG 22
M Tachometer not working following ignition upgrade Austin Healey 10
longbridgehealey Bugeye ignition switch Spridgets 4
J Ignition Key Cylinder Removal Austin Healey 3
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Lin Installation Notes for 1-2-3 Electronic Ignition Austin Healey 1
S Ignition advance weights - how to lube? Austin Healey 5
