paulsherman
I am in the process of converting my Bugeye mechanical tach, using a later model tach. from a Mark 3 Sprite or Mark II Midget. They are the same diameter size as a Bugeye Tach. Everything is going fine, including the process of replacing the face and the needle, changed over thre positive grounf tach guts to negative ground. BUT: When I was putting it back together and starting to install the white loop wire, I discovered that the metal band around the block was missing. Really all I need is the block with a metal band or just the metal band.
Thank you
Paul
Thank you
Paul
