HS2 questions
Rut
Guys, I have one of those questions that will probably end up embarrassing me to no end, but here goes. I’m cleaning up a pair of HS2s prior to rebuild for the Bugeyes 1275 and I’ve rebuilt 6-8 sets of them along with 3-4 sets of HS4s and HS6s. All of them have ended up being good running easy to tune carbs, so I must have been very lucky in my efforts. The throttle discs on this set are the solid variety vs the poppet style and while they have a few scratches on the flat sides they fit the carb throats well. The question I have is that these throttle discs have a little bump out on one side where it fits in the shaft and I’ve never noticed it before. Is this to help with orientation of the disc in the carb above and beyond having the beveled edge fit the carb throat correctly? If so, what’s that orientation?
Thanks, Rut
Not embarrasing at all - off the top of my head the bump goes up and on the high side of the shaft. I presume to keep them from sliding too far.
JP,
Thanks for the response and the ‘bump’ side is mounted inline with the throttle shaft, but I don’t know if left or right. I can’t ever remembering seeing this before, it’s almost as if these discs are handed.
Thanks, Rut
JP,
Thanks, Rut
I wonder if they have slightly less than 90 deg edges - when I say high side I mean the part that hinges up when you open the throttle.
JP,
I hope a picture of the discs will help explain it better.
Rut
All I see is normal wear, Rut. I assume they need throttle shafts at the least.
Kurt.
Kurt,
Enlarge the picture and look at the sides facing each other and you’ll see the tab or bump on the discs. I do need jets and shafts and possibly some viton tipped metering valves for the float bowls...the ABC needles and discs look good (except for the questionable bump), but I’ll need new disc screws (heads are much larger than the originals).
Thanks, Rut
Rut, I see a bump right where the throttle shaft fits which would be caused by wear of the throttle plate moving back and forth. Is that what I should be looking at??
Kurt.
Kurt,
Yes, that’s the spot...so that’s just wear? I’ll order a couple of master rebuild kits and get the show on the road.
Thanks, Rut
Yeah, I think they are pretty worn....the question is, though, will new replacements be better!? I think I would fit them temporarily and see if you think the clearance is really going to be an issue. Just my 0.02!:smile:
Kurt.
pbraun Single HS2 on an 850 Mini Moke acting odd British Motor Corp 10
jehuie HS2 carburetor question… now with video! British Motor Corp 20
jehuie Will this lid work with my HS2 carburetor float chamber? British Motor Corp 4
jehuie Wanted HS2 carburetor float chamber cover wanted Spridgets Classified 0
eschneider Spitfire Float height - '64 spitfire w/ dual HS2 Triumph 1
R SU HS2 rebuilds Spridgets 3
SD Bugeye HS2 interconnecting SS Braided fuel hose Spridgets 7
TomMull Post-War Other SU HS2 caburetor question Triumph 9
sim HS2 Rebuild ? Spridgets 8
AN5Sprite What Needle In Your HS2? Spridgets 3
D K&N RU-4410 on SU HS2's Spridgets 37
J Getting HS2 carb jet out Spridgets 11
T HS2 needles Spridgets 1
histerical Looking for some HS2 parts Spridgets 5
TulsaFred Float bowl to jet connection leak on HS2 Spridgets 8
RichBall HS2 and HS4 measurment Spridgets 7
Gundy HS2 customs Spridgets 8
BugeyeNJ58 Carb leaking HS2 at bottom of float chamber Spridgets 21
TexasSprite Rebushing HS2 Carb throttle shafts Spridgets 7
RickB Air cleaners for HS2 carbs? Spridgets 33
C Single HS4 vs pair of HS2 on a 1275? Spridgets 21
John Moore HS2 Stub Stacks Spridgets 0
T HS2 for 1275, right? Spridgets 7
jvandyke HS2 float level Spridgets 10
pakiwi HS2 - Carb Issue Spridgets 3
mccalebr Eye candy - Hap's HS2 carbs Spridgets 20
Hap Waldrop HS2 velocity stacks Spridgets 37
TexasSprite HS2 Carbs Spridgets 8
58Custom SU HS2 Piston assy movement-- question Spridgets 20
Luke_Healey HS2 question Spridgets 20
Atrus Carb velocity stacks - are these HS2 or HS4? Spridgets 2
Luke_Healey SU HS2 needle variation question Spridgets 11
ChrisS HS2's flooding in turns Racing 5
ChrisS HS2's flooding in turns Spridgets 14
S HS2 SU dual carb throttle/choke linkage Spridgets 10
middleagecrazy HS2 floats Spridgets 9
drooartz HS2 on a 948 Spridgets 3
Atrus HS2 jet needles Spridgets 4
HAN8L1965 Float Removal-SU HS2 Spridgets 5
Atrus [2] HS2 vs [1] HS4 Spridgets 10
M Need to replace fast idle screws for '74 midg. HS2 Spridgets 1
Woodie HS2's and apologies Spridgets 16
Woodie hs2's slight hesitation under load Spridgets 40
Woodie hs2 & vac to dizzy - urgent - car apart in drivewy Spridgets 11
SilentUnicorn hs2 problem Spridgets 7
A T-Series Switch HS2's for HS4's ??? MG 3
C How to check for leaks at throttle shafts? [dual HS2's] Triumph 14
C HS2's...big ole' flat spot! Maybe I need to just pay someone. Triumph 27
D HS2's on a 1500...good, bad or ugly????? MG 17
nathandarby67 WANTED: S.U. HS2 Dashpots [Midget 1275] MG 3
