Luke_Healey
I bought one of those carb tool kits on ebay last year, but the jet centering tool is too large for the application.
Where can I order one that actually works right?
Also, the part in this diagram (item #9) called the Jet Bearing Kit is problematic on my back carb.
It seems as if there is no way to tighten it without throwing the jet off of center, such that the needle bumps it and the dashpot piston binds up. However, I don't have this jet centering tool to aid me in my seemingly fruitless endeavour.
Any tips or tricks? My car runs, but not well. I've purchased a few sets of HS2 carbs on ebay, but they are all for different years and have differing emissions controls, needles, etc... I just want to use what I have, but I am at my wit's end with getting the rear carb set up correctly. Even when using the Colortune tool to set lean and rich, things never work out right. The car seems to run very rich at all times, regardless of how I get it set at idle. Most likely due to needles touching jets and other general badness.
Thanks for any tips or tricks.
I know I've posted about this 40 different times in the past, but I just can't get things adjusted right. I know how to adjust the carbs. It just doesn't seem possible with the situation I'm presented with.
