hs2's slight hesitation under load
Woodie
OK today I got the front carb changed out. It seemed to run fine. After dinner went for a short run. It seems there is some hesitation under load when just starting in 1st gear, it also seems not as smooth when lifting the foot of the gas to coast in 3rd and 4th. With the changes made to vacuum and the carbs any suggestions. ?? When I pull the choke out about 1/3 even when warmed up it smooths out.....
Baz
Air leak on the intake?
Is the rear carb out of whack from changing the 1st?
Definately sounds air related....
jlaird
Are they balanced properly?
Woodie
Woodie
OK here is an thought, while driving to work today. The car started fine, with choke full out, it idled at 2000. After a minute or so I pushed choke in half way. Still idled fine but now about 1500. Pulled out of driveway. A bit hesitant. For the nexty five minutes to avoid the bucking bronco syndrome I pulled the choke full out. At least I could pull away from a stop sort of smooth. Once fully warmed up, with choke in all the way, from a smooth idle of 1000 when I step on the gas until about 2500 rpm she just wants to die. Once past that point she goes like stink, pulled onto the hiway and hit 70 real quick. There is much more power there now than yesterday.
Anyway my thought, I believe when filling the dashpot on the rear carb last time I used 10W30, yesterday when setting up the new carb I used 20W50 (use that in the engine) I am going out at lunch time to remove and rain both pistons and refill with fresh 10W30 or maybe marvel Mystery oil, (any preferences folks??)
I do not believe I have any air leaks cause when I sprayed carb cleaner all over the carbs yesterday the idle did not drop and stall the car out. (actually I think the idle actually increased a bit ???) So I will try the change of oil, and see, otherwise I guess I need to re balance the carbs,,,,(yup yup 12 flats out and 2 full turns on the idle screw, start and adjust)
Baz
[ QUOTE ]
[/ QUOTE ]
If the idle picks up, that would be an air leak, however, I also think 20W50 may be a too heavy also. I have lightweight oil in my pots.
The bad news is, I think you'll have to balance anyway.
Woodie
Woodie
Hmm well I just re read the Su tuning manual, and they say that the back firing that I am experienceing (uneven and such is caused by a weak mixture. So that combined with to thick oil and I amy sort this out at noon. I'm gonna check the little push pin things under the carb. Lift the piston a bit and if she dies out to rich, if she idles faster too weak...
...and be sure that the air cleaner back plate is no upside down. But it sounds like an air leak. Tighten things up and then set the mixture.
Woodie
Woodie
True Jessie True,, I had the plates upside down once before, I will also tighten the carb to intake bolts, the choke shaft nuts, and the throttle shaft nuts. Then do the oil, try it, then adjust as necessary. I'll let you guys know. Thanks
jlaird
Your problem is without question carberation, for crying out loud take 5 min and adjust and balance the carbs after insureing that you have no air leaks.
Woodie
Woodie
Thats what I'm going to do Jack, I'm going to check for leaks, change the oil and re-adjust and balance the carbs I also have to balance a working wife a 4 yr old son, my job, and the car. I worked on the car for 4 hrs yesterday afternoon. Then spent the rest of the evening with my son till 9:30 PM while my wife slept before going to work at 11Pm. So I had 1 1/2 hrs with her. I left for work at 6:30 am..and am here till noon. Then I will go out and get my hands into her for a while. rest assured I do what I can when I can, and I do appreciate you and the others being patient with myself and other rookie car mechanics. I am sure my car would not be running with out your help or lots of cash. I am a proud Midget owner. I love my car. I am unsure of what to do so I try to describe issues here so I can get ideas on where to start. So far this boards help has been supurb, I am constantly amazed that problems (not just mine) can be described diagnosed and fixed with a BBS. oh, and Jack just to let you know, I am working ILS and maintenance issues for the Canadian Navy Submarines (civvy contractor) so being carefull is job trained, maintaining dive certificates is as important as Airworthiness. So I kinda carry that look before you leap into what I do with the car, approaching everything slow and with lots of input. Again thanks and please keep up the great work on this board
I think you know, but it may be necessary to adjust the mixture and balance several times if they are way off. In your case, I'd start with the mixture, then balance, then mixture again if needed. Then final adjustment on the mixture with the air filters in place. Then set your idle.
leecreek
changed one carb? Did you check for match of needle and spring?
Woodie
Woodie
I put the old housing and piston with spring and needle on the replacement body. So same same. The needle is centered as well. with no load the piston rise almost at same speed it only faulters under load....
Morris
Hey Woodie,
I have been following your thread, and I have a concern about how you set up your spark advance. I don't have a lot of experience with the 1275 set up, so take this advice with a grain of salt...
Because on your old carb, the tube for the advance was coming from the carb, that makes me think that the advance is supposed to be ported. This means that the advance gets no or little vacuum at idle. Vacuum is applied as the throttle opens up. If you are getting backfiring on deceleration, it may be due to an overly advanced ignition. In other words, if your advance is meant to be ported, when you let off the throttle, your spark should be getting no advance. But since your advance tube is plugged into the manifold, you are getting way too much advance and your spark is hitting while the valves are still open causing a backfire.
It's never a bad idea to check for vacuum leaks and balance the carbs. But as an experiment, you may try plugging your vacuum advance, checking your ignition timing, and givin' her a test drive with the advance plugged.
Woodie
Woodie
Morris I love salt... Thanks, I will take the vac hose of the intake and take her for a short spin to warm her up so to speak, see how it drives. If no change then I guess I go ahead and do the other stuff. If however there is improvement, what do I do about dizzy vacuum advance,? Can I leave it plugged or not or should I find a new source of vacuum. If you look at this picture, you can see the vacuum hose to the dizzy of the carb, behind the butterfly. I moved the hose to the port on the intake (where the philips screw was. )
OK, I've been trying to decide why the DPO changed only the front carb. Maybe it was because he needed a ported vacuum source to go with a distributor that is not original to the car. I'd test as Morris said, and if it solves the problem then I'd look for a correct distributor with an advance curve better suited to your engine.
Woodie
Woodie
oh, ok Trev, thanks. I am on my way out to test the car etc etc now. Be back in about an hour or so and will report on my findings/results... Wish me luck....
Woodie
Woodie
Well I removed the vacuum to the dizzy and plugged it, car would not run, stalled out, Blah. So back on it went. I removed air filters and it is the front carb that when gas is given it sputters and dies. I leaned it way out, same thing. So I tried the other way, rich, about 3 or 3 1/4 turns, seems to have solved or almost solved the issue. I took a short run, with 3 stop starts or so and the hesitation is gone. The idle is a bit high, but I can turn that down quick enough. But the car does not drop back to idle quickly?? I can't hear any air leaks, I had no spray, I will check again at home tonight, but I tightened everything up again.
jlaird
Hmm, I still say work on balanceing and getting the carbs adjusted. No question in my mind.
Woodie
Woodie
Oh I agree Jack, I figure a hour or two of trial and error, or goto the local LBC mechanic and give him $50 buck to do it.....but where the satisfaction in that eh?? (Can you tell I'm Canadian) Which brings me to the subject of Beer,,Im still at work and get have one for a while yet
pbraun Single HS2 on an 850 Mini Moke acting odd British Motor Corp 10
jehuie HS2 carburetor question… now with video! British Motor Corp 20
jehuie Will this lid work with my HS2 carburetor float chamber? British Motor Corp 4
jehuie Wanted HS2 carburetor float chamber cover wanted Spridgets Classified 0
eschneider Spitfire Float height - '64 spitfire w/ dual HS2 Triumph 1
Rut HS2 questions Spridgets 9
R SU HS2 rebuilds Spridgets 3
SD Bugeye HS2 interconnecting SS Braided fuel hose Spridgets 7
TomMull Post-War Other SU HS2 caburetor question Triumph 9
sim HS2 Rebuild ? Spridgets 8
AN5Sprite What Needle In Your HS2? Spridgets 3
D K&N RU-4410 on SU HS2's Spridgets 37
J Getting HS2 carb jet out Spridgets 11
T HS2 needles Spridgets 1
histerical Looking for some HS2 parts Spridgets 5
TulsaFred Float bowl to jet connection leak on HS2 Spridgets 8
RichBall HS2 and HS4 measurment Spridgets 7
Gundy HS2 customs Spridgets 8
BugeyeNJ58 Carb leaking HS2 at bottom of float chamber Spridgets 21
TexasSprite Rebushing HS2 Carb throttle shafts Spridgets 7
RickB Air cleaners for HS2 carbs? Spridgets 33
C Single HS4 vs pair of HS2 on a 1275? Spridgets 21
John Moore HS2 Stub Stacks Spridgets 0
T HS2 for 1275, right? Spridgets 7
jvandyke HS2 float level Spridgets 10
pakiwi HS2 - Carb Issue Spridgets 3
mccalebr Eye candy - Hap's HS2 carbs Spridgets 20
Hap Waldrop HS2 velocity stacks Spridgets 37
TexasSprite HS2 Carbs Spridgets 8
58Custom SU HS2 Piston assy movement-- question Spridgets 20
Luke_Healey HS2 question Spridgets 20
Atrus Carb velocity stacks - are these HS2 or HS4? Spridgets 2
Luke_Healey SU HS2 needle variation question Spridgets 11
ChrisS HS2's flooding in turns Racing 5
ChrisS HS2's flooding in turns Spridgets 14
S HS2 SU dual carb throttle/choke linkage Spridgets 10
middleagecrazy HS2 floats Spridgets 9
drooartz HS2 on a 948 Spridgets 3
Atrus HS2 jet needles Spridgets 4
HAN8L1965 Float Removal-SU HS2 Spridgets 5
Atrus [2] HS2 vs [1] HS4 Spridgets 10
M Need to replace fast idle screws for '74 midg. HS2 Spridgets 1
Woodie HS2's and apologies Spridgets 16
Woodie hs2 & vac to dizzy - urgent - car apart in drivewy Spridgets 11
SilentUnicorn hs2 problem Spridgets 7
A T-Series Switch HS2's for HS4's ??? MG 3
C How to check for leaks at throttle shafts? [dual HS2's] Triumph 14
C HS2's...big ole' flat spot! Maybe I need to just pay someone. Triumph 27
D HS2's on a 1500...good, bad or ugly????? MG 17
nathandarby67 WANTED: S.U. HS2 Dashpots [Midget 1275] MG 3
