HS2 velocity stacks
One of the problems I have with HS2s, is there isn't any real nice velocity stack available, well any that are user friendly anyway. For the most part you have these backplate/frontpalte air fliter set ups, that have fastners runing inside air filter flow, and if you need to get in there and work on the carbs, you have to pull that whole abomination out of the way. What many of use racing twin HS4s on 1275 race engine in SCCA have doen for years is use the HS4/MGB factory velocity stack which is 3.5" OD, attach via counter sunk/bore fastners directly to the carb front and then run a universal K&N filter on the factory stack, the K&N filter has a rubber base that just slips over the 3.5 OD and is hel on with a simple clamp, which is supplied with the K&N cone filter. OK, with that being said I, in the last years made a batch of CNC radiused velocity stacks for the HS6 carbs, used very commonly oon the MGBs in vintage and SCCA racing, those all got gone like hotcakes, in the back of my mind I thought the HS2s guys need the same thing. It flows good, Vizard recognize this set up as the flowing shape and length, and in 2 secong you can pull the ait fliter out of the way, so no set up is more user friendly. Now I not breaking any ground here, I made some on-off before for the HS2, so has Huffaker, and many others, but it always seems these deals are done in short production runs, and when it done and there gone, thats it. Well the punchline is I'm getting ready to do a run of these, and anyone who may be interested might want a set would need to contact me.
In the photos below, I have Ray Mccalebs, freshly done HS2 set, and I'm holding the HS6 CNC stack we made up aginst one the carb throats, so a little imagination will be requires. What I want to do is have the ID of them made to match a stock unmodified HS2 carb opeing, and with the HS2, you have only one vent hole, so there will be fornt and rear units, and asl because of the threads in the HS2, we would counter bore for mounting hardware on the fornt, it would be the same 3.5 OD, so we could use the K&N Filter, which fit niocely in a Spridget's engine bay with no trouble, I have ran this set up on my race cars in the past. So here have a look, and,let me know what you think. I'm not really palnning on stocking these, so it's one of those things you get in on the production run or you may not get a set.
Hap Waldrop
OK, here's a set of the HS6 units on a set of race carbs I built, and aslo a picture of my personal MGB with the K&N cone filters on the HS4s, the same filter this set would use.
drooartz
Count me in for a set, Hap. I've got that nice motor and fresh, clean carbs you did for me.
TexasSprite
Put me on the list as well. I've got a recently refurbished set of HS2s that they would look fine on. I like the K&N filter arrangement!
VelodromeRacer
Hap-
I am in as well...then soon we will get you to also do a engine build too!
Pythias
Nice. For those who don't run stacks already, GET SOME!
Let me say it again.. GET SOME!!
There is a hill that is a part of one of my regular "runs". One day I made the run and going up the hill I had to downshift from 4th to 3rd to make it up. The very next day, essentially the same atmospheric conditions, I installed a set of stub stacks (I got 'em off Ebay from, as it turned out Joe Huffaker!) inside K&N DEEP (3") filters. When I went up the hill I ACCELERATED in 4th gear.
As an aside, I now have stub stacks instead of the 1 1/2" tall ones which sit on my shelf. Waiting.
Hap is correct about the hassle but with the arrangement I have now it's just a matter of pulling the filter. The back plate can stay in place and so can the stubs when tuning the carbs.
mccalebr
Hap and I had a lengthy discussion about this item, in conjunction with the carb rebuild, when he finished my engine build. I had drooled over the ones he made for the larger carbs and REALLY wanted a set for the new 1275.
Last week when Hap called to say the carbs were ready, we went back to that discussion. First set off this run is mine!!!
I have a pair of the spun stacks that were available for a while (you can see the ones I'm talking about here):
https://www.raysmg.com/Web%20Images/Edite...07/P1010020.jpg
They did not look right, but more importantly did not fit right...additional machining would be required. Not to mention that once fitted, what to do about filtration? The standard solution were the foam "socks", but to keep the socks from crushing down during hard acceleration you had to insert a rolled piece of perforated metal. Now that metal (filter plate) to metal (stack) is really going to do a number on the polish job you worked so hard to put on those stacks...NOT a solution in my mind.
So, when Hap mentioned that he might consider doing a run, I jumped (and wrote a check). The spun stacks and socks I already have go up on Ebay soon; for what they cost, you'd be well on your way to buying the set made by Hap.
I'm sold!
Ray
Pythias
As an interesting side note, the ones from Huffaker are the only ones I've ever seen that have a channel for the "relief" hole fed from inside the stack, instead of just a hole in the base. They also have a built in "rock screen". Not enough to stop particulates, but big enough to stop a 1/4-20 nut. ...
Hap, any idea how much yours are going to cost? Or is it dependent upon the size of the run?
BugEyeBear
I'm interested...
Now I just need to decide how many sets to request...
-Bear-
chrpark
very interested, too. was planning on the judson supercharger to replace the HS2's but wondering about the $/HP tradeoff... and why trash a perfectly good set of HS2s if there's a good intake/filter option available? wonder what Vizard would say
Hap Waldrop
Well, looks like you guys are interested, as soon as I get more details (a week or two)I let you all know.
Dadandson
Hap, These are the stacks I made. A note of caution; I had to machine the OD of the stacks at the angle that the carbs sit on the manifold to allow the hood to close with the K&N's attached. If I left the OD parallel to the ID the hood would not close. I can send you the drawings I created in PDF form if you like. I ran them on one of my Okuma CNC lathes.
Dadandson
Second Pic
Dadandson
Completely assembled
pakiwi
Hap,
I would be interested in more info on these. Just working on teh Carbs now, then get to tune them for the first time ever.
Tks
Allan
Platinum
With all the interest, my opinion will be just another log onna fire here, but: Anyone with HS2's should JUMP on Hap's offer. Those contoured stacks will be a noticeable improvement even on a rock-stock setup. Much better flow at entry, no transitional disturbance. Great little improvement to volumetric efficiency.
Elegant!
:thumbsup:
Hap Waldrop
Sure, I'd take you up on that.
Atrus Carb velocity stacks - are these HS2 or HS4? Spridgets 2
pbraun Single HS2 on an 850 Mini Moke acting odd British Motor Corp 10
jehuie HS2 carburetor question… now with video! British Motor Corp 20
jehuie Will this lid work with my HS2 carburetor float chamber? British Motor Corp 4
jehuie Wanted HS2 carburetor float chamber cover wanted Spridgets Classified 0
eschneider Spitfire Float height - '64 spitfire w/ dual HS2 Triumph 1
Rut HS2 questions Spridgets 9
R SU HS2 rebuilds Spridgets 3
SD Bugeye HS2 interconnecting SS Braided fuel hose Spridgets 7
TomMull Post-War Other SU HS2 caburetor question Triumph 9
sim HS2 Rebuild ? Spridgets 8
AN5Sprite What Needle In Your HS2? Spridgets 3
D K&N RU-4410 on SU HS2's Spridgets 37
J Getting HS2 carb jet out Spridgets 11
T HS2 needles Spridgets 1
histerical Looking for some HS2 parts Spridgets 5
TulsaFred Float bowl to jet connection leak on HS2 Spridgets 8
RichBall HS2 and HS4 measurment Spridgets 7
Gundy HS2 customs Spridgets 8
BugeyeNJ58 Carb leaking HS2 at bottom of float chamber Spridgets 21
TexasSprite Rebushing HS2 Carb throttle shafts Spridgets 7
RickB Air cleaners for HS2 carbs? Spridgets 33
C Single HS4 vs pair of HS2 on a 1275? Spridgets 21
John Moore HS2 Stub Stacks Spridgets 0
T HS2 for 1275, right? Spridgets 7
jvandyke HS2 float level Spridgets 10
pakiwi HS2 - Carb Issue Spridgets 3
mccalebr Eye candy - Hap's HS2 carbs Spridgets 20
TexasSprite HS2 Carbs Spridgets 8
58Custom SU HS2 Piston assy movement-- question Spridgets 20
Luke_Healey HS2 question Spridgets 20
Luke_Healey SU HS2 needle variation question Spridgets 11
ChrisS HS2's flooding in turns Racing 5
ChrisS HS2's flooding in turns Spridgets 14
S HS2 SU dual carb throttle/choke linkage Spridgets 10
middleagecrazy HS2 floats Spridgets 9
drooartz HS2 on a 948 Spridgets 3
Atrus HS2 jet needles Spridgets 4
HAN8L1965 Float Removal-SU HS2 Spridgets 5
Atrus [2] HS2 vs [1] HS4 Spridgets 10
M Need to replace fast idle screws for '74 midg. HS2 Spridgets 1
Woodie HS2's and apologies Spridgets 16
Woodie hs2's slight hesitation under load Spridgets 40
Woodie hs2 & vac to dizzy - urgent - car apart in drivewy Spridgets 11
SilentUnicorn hs2 problem Spridgets 7
A T-Series Switch HS2's for HS4's ??? MG 3
C How to check for leaks at throttle shafts? [dual HS2's] Triumph 14
C HS2's...big ole' flat spot! Maybe I need to just pay someone. Triumph 27
D HS2's on a 1500...good, bad or ugly????? MG 17
nathandarby67 WANTED: S.U. HS2 Dashpots [Midget 1275] MG 3
