[2] HS2 vs [1] HS4
Atrus
Once again, per my Megasquirt post on this page, I am trying to determine what I'd want to use as a throttle plate for an FI setup.
I may be thinking about this all wrong, however, currently my 1275 has 2 HS2's. For ease of implementing an FI system, I was now considering swapping to a single HS4.
HS4 = 1.50" = 1.767 sq. inches
HS2 = 1.25" = 1.227 sq inches, multipled by 2 = 2.454
So, wouldn't a HS4 be restrictive on the engine?
P.S. - I am awaiting Vizard's book to arrive, so bear with me! /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
Bugeye58
Kevin, most of the 1275 single carb conversions I've seen use a single HIF 44. Roughly a 1.732" throttle bore.
I ran a single HS4 on my 1500 Spit, but it was heavily tweaked for racing.
Jeff
Atrus
Atrus
Jeff,
Like I said, no Vizard's book yet, but basically I want to perk the engine up a little - maybe some mild head work (porting/polishing), street cam, perhaps a bore - .020" or .030". It's all speculation now until I really read up on how these engines respond to various mods, however, I'd just like to make the car a little quicker and peppier for cruising around here on weekends.
So, if most people do the HIF 44, I'd be safe to think the HS4 isn't being too restrictive?
Bugeye58
Kevin, depending on the attendant mods, I think you can get away with a single HS4. The HIF 44 is a metric carb, ie 44mm bore, or nearly 1 3/4".
But, on a high performance 1275 I run twin HS4's. The only reason I ran a single on the 1500 was due to rules restrictions.
Jeff
no_cones_ever
if you could find a HIF 44 you would either have to build your own manifold or get one off of a mg metro and the single is what i am thinking of doing on my 948cc just because i don't want to have to tune two carbs
Bugeye58
A single HIF 44 is <u>way</u> too much carb for a 948. Remember, they had 1 1/8" carbs originally.
But, what do I know?
Jeff
no_cones_ever
upon further research i am going to do a single 1.5...and i have an mk2 which means that i have a 9cc enging which means 1 1/4 inch carbs
jcatnite
Jeff...you've probably forgot more than most of us will know about these little cars. Keep the advice coming.
JC
Atrus
Atrus
Would you say a 56mm bore on the throttle would be far too big for a lightly modded 1275? (I'm scheming)
RichBall HS2 and HS4 measurment Spridgets 7
C Single HS4 vs pair of HS2 on a 1275? Spridgets 21
Atrus Carb velocity stacks - are these HS2 or HS4? Spridgets 2
A T-Series Switch HS2's for HS4's ??? MG 3
pbraun Single HS2 on an 850 Mini Moke acting odd British Motor Corp 10
jehuie HS2 carburetor question… now with video! British Motor Corp 20
jehuie Will this lid work with my HS2 carburetor float chamber? British Motor Corp 4
jehuie Wanted HS2 carburetor float chamber cover wanted Spridgets Classified 0
eschneider Spitfire Float height - '64 spitfire w/ dual HS2 Triumph 1
Rut HS2 questions Spridgets 9
R SU HS2 rebuilds Spridgets 3
SD Bugeye HS2 interconnecting SS Braided fuel hose Spridgets 7
TomMull Post-War Other SU HS2 caburetor question Triumph 9
sim HS2 Rebuild ? Spridgets 8
AN5Sprite What Needle In Your HS2? Spridgets 3
D K&N RU-4410 on SU HS2's Spridgets 37
J Getting HS2 carb jet out Spridgets 11
T HS2 needles Spridgets 1
histerical Looking for some HS2 parts Spridgets 5
TulsaFred Float bowl to jet connection leak on HS2 Spridgets 8
Gundy HS2 customs Spridgets 8
BugeyeNJ58 Carb leaking HS2 at bottom of float chamber Spridgets 21
TexasSprite Rebushing HS2 Carb throttle shafts Spridgets 7
RickB Air cleaners for HS2 carbs? Spridgets 33
John Moore HS2 Stub Stacks Spridgets 0
T HS2 for 1275, right? Spridgets 7
jvandyke HS2 float level Spridgets 10
pakiwi HS2 - Carb Issue Spridgets 3
mccalebr Eye candy - Hap's HS2 carbs Spridgets 20
Hap Waldrop HS2 velocity stacks Spridgets 37
TexasSprite HS2 Carbs Spridgets 8
58Custom SU HS2 Piston assy movement-- question Spridgets 20
Luke_Healey HS2 question Spridgets 20
Luke_Healey SU HS2 needle variation question Spridgets 11
ChrisS HS2's flooding in turns Racing 5
ChrisS HS2's flooding in turns Spridgets 14
S HS2 SU dual carb throttle/choke linkage Spridgets 10
middleagecrazy HS2 floats Spridgets 9
drooartz HS2 on a 948 Spridgets 3
Atrus HS2 jet needles Spridgets 4
HAN8L1965 Float Removal-SU HS2 Spridgets 5
M Need to replace fast idle screws for '74 midg. HS2 Spridgets 1
Woodie HS2's and apologies Spridgets 16
Woodie hs2's slight hesitation under load Spridgets 40
Woodie hs2 & vac to dizzy - urgent - car apart in drivewy Spridgets 11
SilentUnicorn hs2 problem Spridgets 7
C How to check for leaks at throttle shafts? [dual HS2's] Triumph 14
C HS2's...big ole' flat spot! Maybe I need to just pay someone. Triumph 27
D HS2's on a 1500...good, bad or ugly????? MG 17
nathandarby67 WANTED: S.U. HS2 Dashpots [Midget 1275] MG 3
