ChrisS
I have a set of SU HS2’s on my track car and I’m having a problem where the car will flood in tight turns. The fuel pressure is 1.5-2psi set by a bypass regulator. The carbs have the non-adjustable plastic floats. I have tried shimming the seat to lower the fuel level but it got to the point where the valve wouldn’t open (since the hinge point is fixed it starts to bind). So what am I missing? I’m going to try to locate a set of adjustable floats but I’m curious as to others thoughts. My solution yesterday was to shut off the fuel pump after just before the turns and then back on in the straights but that was a bit cumbersome – especially when I fat fingered the ignition switch also. This is cross posted in the spridget forum.
