HAN8L1965
Need some help before I destroy sometning, how do you remove the pin holding the float in place, or how do you remove the float. I noticed that there are different plastic floats in each of my carbs. The front carb deffinetly needs the pin removed to get the float out. I bent the retaining hinge clip of the other to remove it. I want to soak the cap in cleaner but you can't put plastic in the solvent.
Mark
Mark
