HD6 1-1/2" SU Front [L/H] Float Chamber
Lin
Hi folks,
I am looking for the front float chamber for HD6 carbs. Would prefer #AUC4067 or #AUC 2067 will work. I don't need the lid - just the bowl. Anyone have a spare with which they will part? Feel free to PM me if you prefer.
Thanks!
Lin Rose
S Leaking HD6 Rear Carb Austin Healey 10
steveg TR6 HD6 carbs on TR6? Triumph 16
AH67 For Sale CARBURETOR REBUILD KIT, genuine SU, twin HD6 Austin Healey Classifieds 0
F How to restore screws, springs and fixings on SU HD6 Carburetors? Austin Healey 7
jfarris For Sale Air Horns for SU HD6 Carbs Triumph Classifieds 4
J SU HD6 - Slow Idle Screw Austin Healey 13
C HD6 Carburetor Spacer Blocks Austin Healey 4
F Follow on questions from HD6 carburetor rebuild Austin Healey 5
F How important is getting the float height correct on SU HD6 carbs? Austin Healey 3
F Adivce on how to center jets of SU HD6 carbs Austin Healey 3
Lin K&N Air Filters for SU HD6 carbs Austin Healey 14
B SU-HD6 Gas Leaks Austin Healey 6
B Adjusting SU-HD6 Carbs Austin Healey 2
britndablood HD6 jet diaphragm only lasted 8 months Austin Healey 7
N HD6 / 8 carbs. Austin Healey 13
BOBBYR HD6 CARBURATORS????? Austin Healey 3
I Setting up / Tuning an HD6 Carb Austin Healey 3
red57 Fitting 3 HD6 to 6 cy Healey Austin Healey 10
DerekJ Triple 3/4" SU's HD6 Austin Healey 12
J What are HD6 carbs worth? Austin Healey 0
G HD6 Question - on TR6 Austin Healey 4
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
bighealeysource Front Brake Adjusters Austin Healey 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
G Rebuilding Front Seats Austin Healey 4
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
