Synchromesh Hub End Float
AUSMHLY
The green Austin Healey 100/6 and 3000 workshop manual, General Data, page 15 states:
Synchromesh hubs: End float,
2nd speed, .007 in (.18mm)
3rd and 4th speeds, .031 in (.8mm)
It doesn't specify which model Healey.
I'm not up to speed on what that means.
How does one get that desired end float?
I'm only familiar with the laygear end float which uses thrust washers of different thicknesses to achieve the required end float of 0.012.
5 4 speed reproduction synchromesh cones Austin Healey 0
DenverMGB Synchromesh Gone - Options? MG 9
K Sprite/Midget synchromesh Trans ? Spridgets 3
mctriumph TR2/3/3A Hub cap emblems Triumph 2
D Removing the steering wheel hub Spridgets 12
Carlbanan56 MGB Front hub MG 4
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
B TR4/4A Steering Wheel Hub Issues Triumph 0
M T-Series MG TD 1st/2nd sliding hub end play MG 1
A BN7 Front Hub Stud Nuts Austin Healey 5
Lin Bugeye Axle Hub & Bearings Austin Healey 1
W Rear Axle Hub Seal Austin Healey 8
R TR2/3/3A Steering wheel hub removal Triumph 11
AUSMHLY First Gear Sliding Hub Endplay Austin Healey 1
AUSMHLY Transmission Sliding Hub Plungers Austin Healey 9
K TR2/3/3A Securing new brake disc to the front hub? Triumph 4
W Rear Hub Reassembly Austin Healey 7
A Later drum backing plates - hub not clearing Spridgets 2
steveg SOLD!! Moto-Lita 14" wheel for sale with adjustable hub & collet Austin Healey Classifieds 0
K TR2/3/3A Front Hub and Felt Seal Triumph 1
M TR2/3/3A Re-Assembling Rear Axle Outer Bearing and Hub Triumph 1
69MGC MGC Need one MGB/C Splined Hub MG 1
69MGC Wanted Need one MGB/C Splined Hub MG Classifieds 4
Got_All_4 TR6 drill and tap for a grease fitting tr6 rear hub assembly Triumph 4
M Spitfire Triumph spit flange/hub removal Triumph 13
Got_All_4 TR6 Differential side hub measurement Triumph 1
B Wanted Hub Austin Healey Classifieds 4
Zitch For Sale Les Leston Wood Steering wheel with Triumph hub and boss Triumph Classifieds 0
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
Tybalt Spitfire Spitfire vs GT6 Front Hub Question Triumph 0
K For Sale TR3 Hub...short studs Triumph Classifieds 0
Rob Glasgow Rear Hub Nuts Austin Healey 11
B TR4/4A 3rd/top gear syncro hub Triumph 2
Sopwith_Camel hub of the action Jaguar 5
BJ8Healeys Torque on Midget rear wheel hub nut Spridgets 7
P TR2/3/3A Rear axle hub dis-assembly Triumph 1
J TR4/4A Hub out of round? Triumph 2
MikeAH100M 100 Front Hub Spacer/Distance Piece Austin Healey 2
F For Sale Disc Wheel Hub, From Bn7 Austin Healey Classifieds 5
H TR4/4A Leaking ft hub seals Triumph 5
J For Sale Header, hub caps Spridgets Classified 1
55modified Nardi hub for a BN1? Austin Healey 10
warwick-steve Missing grease cap in front hub Austin Healey 8
Lin Rear Axle Hub Nuts Austin Healey 3
warwick-steve Front hub bearing grease repacking Austin Healey 28
J TR2/3/3A Hole in Rear Hub Triumph 7
K TR2/3/3A Front hub oil seal Felt? Triumph 1
K TR2/3/3A Front wheel hub "felt" again? Triumph 2
