4 speed reproduction synchromesh cones
5
57_BN4
Just a little note on my experience with repro sychro cones for a BN4 transmission.
The first lot I got from AH4H looked to be well made so I dutifully assembled the transmission with them. A quick test on the dyno stand showed they have almost no baulking action at all so I stripped down the trans again to find out why. The issue is the lack of care when machining the braking face which mates to the cone shape on the gear.
Pic one is the AH4H supplied synchro after lapping it on the gear for about half an hour then colouring it black with a permanent marker pen and rubbing it a few times on the mating gear.
Pic two is a 'Welch' CGBS140 synchro after the marker pen treatment but with no lapping.
Pic three is the original 55 year old cone.
You can plainly see the differences- the cheapy replacement ones have very little contact area (light colour = contact) due to poor machining when compared to the original and properly made reproduction. They are going straight back to AH4H [edit]
Conclusion: avoid reproduction synchro cones like the plague unless they are properly made. If you are about to assemble a gearbox with repro cones, colour in the brake face and see how much contact it makes with the mating gear.
Andy.
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
PAUL161 Jag 5 speed? Jaguar 5
T Datsun 5 speed potentially available from wrecker: Spridgets 0
Bayless What oil for Datsun 5 speed? Spridgets 7
L General MG Five speed MG 6
K Putting a Getrag 5 speed OD transmission in a Jaguar Mkll ? Jaguar 4
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G 5-Speed Conversions Austin Healey 15
J TR2/3/3A TR3 Soft top speed limit? Triumph 9
Michael Oritt Pilot Bearing Adapter for Smitty's 5-Speed Kit Austin Healey 3
T Rut's 4 speed shifter modification - anyone have knowledge? Spridgets 3
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
shadowfever Datsun 5-speed info neede Spridgets 5
Michael Oritt Smitty's Five-Speed Manual Austin Healey 1
S TR2/3/3A Moss Motors Vitesse 5 Speed Conversion Kit Installation Issues Triumph 13
PAUL161 T-Series 5 Speed Road Test MG 25
PAUL161 T-Series 5 Speed Transmission MG 85
WHT Tremec T-5 Five-Speed Transmission Austin Healey 39
Michael Oritt Difficult-Shifting Toyota Five-Speed Austin Healey 17
crispy Idle Speed Variation Austin Healey 19
Cappy Toyota 5-Speed Austin Healey 3
Cappy Toyota 5 Speed transmission Austin Healey 4
T Wedge TR7 4 speed wheel cylinders on 5 speed (locating pin) Triumph 0
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
T maybe a Datsun 210 5 speed available in Oakland? Spridgets 2
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
I GT6 A type OD vs D type - engagement speed? Triumph 3
HealeyRick Toyota 5 Speed - Truck or Supra? Austin Healey 16
Michael Oritt Toyota 5-speed shifter bushing Austin Healey 7
roscoe 5 speed conversion question Austin Healey 9
Lin Toyota 5-speed bell housing drain hole Austin Healey 14
S For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE Austin Healey Classifieds 1
roscoe Caving In [5-speed conversion for BN2] Austin Healey 29
HealeyPassion Aftermarket heater/defroster with 3 speed fan Austin Healey 15
Editor_Reid “Healey: Cars for Speed & Glamour” Exhibition Austin Healey 5
S TR2/3/3A Speed O not working Triumph 27
M TR6 5 speed conversion Triumph 33
PAUL161 T-Series Who's still building 5 speed conversions. MG 4
Zitch For Sale TR4 - 4 Speed Triumph Classifieds 7
mctriumph For Sale 5 speed kits for supra conversion Triumph Classifieds 0
B "Healey 5-Speed"/Pete Delaney Contact Austin Healey 27
M 5-speed, 1968, 4.2, E-Type, OTS Jaguar 3
Bayless Question on 1 speed wiper motor Spridgets 2
Rut 5 speed install Spridgets 14
drooartz Leaking 5-speed drain plug Spridgets 26
Michael Oritt Toyota 5-speed Problem Austin Healey 28
F TR6 Squeal When Turning Sharply at Low Speed Triumph 6
S Wedge 4-speed gearbox problem Triumph 6
