Float Removal-SU HS2
HAN8L1965
Need some help before I destroy sometning, how do you remove the pin holding the float in place, or how do you remove the float. I noticed that there are different plastic floats in each of my carbs. The front carb deffinetly needs the pin removed to get the float out. I bent the retaining hinge clip of the other to remove it. I want to soak the cap in cleaner but you can't put plastic in the solvent.
Mark
one side of the pin has a flat on it just hold on to it with a pair of pliers and it should pull straight out
sometimes not a flat.....
sometimes a knurled o.d. on the last 1/4" of the float pin ....some times not.
A small pin punch or solid rod about 1 to 3" long and a large opening pair of Channel-locks. Gently press out the pin.
Well it does not have a flat end or a knurled end, it seems to be round but it is not budging. I put it in a vise and tapped it with a hammer and try to pull it with grips and compress it with channel locks. Any other suggestions?
""""""Any other suggestions? """"""
The brass pin is held in two pillars that are part of the float lid casting.
The pin is pressed in one side of one pillar and goes over and thru to the other side and into that pillar.
If corosion is evident you might soak with a bit of P-Blaster or other solvent.
The lid is quite hard to hold with the float attached, as there is no where to grab it in soft jaws. Certainly you dont want to grab across the outer edges.
So then you use the Channel locks open wide and a very short pin punch or rod 1" long that pushes against the pin and squeeze the pin out the other side. not a two handed squeeze as you could break one of the pillars.
I zenith stromberg float brass plug removal help Triumph 14
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
Briancole702 MGB-GT 71 Mgb gt no gas in float bowls MG 1
jehuie Will this lid work with my HS2 carburetor float chamber? British Motor Corp 4
jehuie Wanted HS2 carburetor float chamber cover wanted Spridgets Classified 0
dripdripdrip TR2/3/3A Deformed float bowl Triumph 7
AUSMHLY Synchromesh Hub End Float Austin Healey 1
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
S Carb Float Levers Austin Healey 9
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
GeorgeC HS 2 float adjustment Spridgets 5
K TR2/3/3A Front wheel bearing adjust and end float?? Triumph 10
J TR6 End Float Triumph 5
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
eschneider Spitfire Float height - '64 spitfire w/ dual HS2 Triumph 1
T TR6 Carb. Float Chamber Fix Triumph 5
2 General TR SU float settings Triumph 3
jfarris TR2/3/3A Metal washers for SU H6 float bowls Triumph 1
S TR2/3/3A understanding the float and needle set up better Triumph 6
sundown TR6 Fuel float Triumph 3
K TR2/3/3A Gas Gauge sending unit "float" orientation? Triumph 5
Healey Nut Carb float Austin Healey 16
dklawson GT6 Float Height, 150CD [Early CD, Not Later CDSE or CD2SE] Triumph 7
Merlin63Tr4 TR4/4A Cracked Zenith-Stromberg float assemblies Triumph 13
R TR2/3/3A Establishing distributor shaft end float Triumph 4
S BJ8 Float Level Austin Healey 37
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
M TR2/3/3A SU H Type Carberator Float Lever Adjustment Triumph 10
Lin HD6 1-1/2" SU Front [L/H] Float Chamber Austin Healey 1
Talon TR2/3/3A Float lever issue on SU type H carbs Triumph 1
R Front wheel bearing - end float Austin Healey 40
Lin Post in float bowl came loose Austin Healey 6
steveg Carb float setting tool Austin Healey 11
KVH General Tech Distributor Gear End Float Triumph 6
BN6_2197 Advice on removing the float from the chamber Austin Healey 6
F Wanted TR3 Front Float Bowl Lid SU H6 Triumph Classifieds 6
Tinkerman TR2/3/3A TR3A SU H6 Rebuild Float chamber Cap Nut Triumph 3
GBRandy MGB HIF float chamber seals MG 6
D BJ 8 Float Bowl securing bolt loose Austin Healey 6
J BJ8 Float bowl vent pipes Austin Healey 11
KVH TR4/4A Carburetor float bowls Triumph 8
Zimmycobra TR4/4A Who's right - float height on ZS 175CD? Triumph 5
J TR4/4A Transmission counter shaft end float. Triumph 3
busybrit Healey 3000 distributor drive gear spacer washer, end float! Austin Healey 2
Martinld123 Push button on top of new H6 carbs float bowl from Moss Austin Healey 3
T TR2/3/3A SU H6 float level Triumph 4
H TR2/3/3A SU Carb Float Question Triumph 18
C TR6 Carb float chambers Triumph 7
S Float valves for HD8 - Grose Type Austin Healey 20
