HS2 float level
jvandyke
Should be 1/8" as in picture, not like the red area (as mine are now) I assume, even with Grose jets (can't see how would matter)? I should bend to get more clearance right where the hinge pin goes through? I might have 1/8" inch clearance at the center but the whole float is angled.
Platinum
You should be able to straighten the float on the arm with some careful bending.
...and see your other post for where to bend it to adjust the clearance.
jvandyke
jvandyke
Thanks, missed your other post or I wouldn't have started a new thread so quick, bad poster, bad! Sorry.
jvandyke
jvandyke
maybe those grose jets throw things off? Do they sit higher (actually lower, longer, sticking into the float chamber more) than OEM? If I watch the ball in the jet, holding assembly vertical, the ball starts to get compressed when the float is WAY further out than 1/8", closer to a 1/2". In operation that means much lower float level. Maybe this is why the PO ditched the SUs so many years ago? Looks like the step in the arm between float and pivot point should be taken out, wonder if that would move the float to far off center in the bowl. Hate to mod it so much and then decide to ditch the grose jets, after the floats are past the point of no return. I have to imagine this has been addressed many many times in the last 40 odd years.
PS I do have some sort of washer under the jet, removing that and turning the jet in some more would help.
This is one reference
Platinum
Welllll... my personal opinion of Gross(e) Jets is my own... I think they're ~almost~ good WristRocket ammo. Not good for much else. A set of Viton tipped replacements would be MY suggestion before you go tweakin' the float arms.
jvandyke
jvandyke
Yeah, I know, many hate those things, many swear by them, many swear at them, but they're there so before I go replacing EVERY part I thought I'd start out replacing as little as I could and see what's what.
I took the "washer" out from under the jet. When held vertical it's set such that the float (bracket) is 1/8" away from the housing right as it contacts the ball in the grose jet. But set like that, my float is still angled quite a bit, wondering now if that's okay.
Here's a picture. I should say it reaches 1/8" just as the grose jet closes off the flow (of air from my mouth). Maybe I'm beating this to death needlessly.
Platinum
I'd say you're good to go. Slap 'em together and bolt 'em up. :wink:
jvandyke
jvandyke
Leading edge? Sorry to be so ignorant.
tempting to put in a drain petlock, so you can attach a tube to it, hold it along side the chamber, open the valve and see exactly where the level is as it's operating (like motorcycle carbs). Wonder if there is a measurement relative to the float chamber of proper fuel level. Test it on the bench.
JPSmit
leading edge of float
jlaird
Like Doc says, you are good to go. Bolt it up and take a ride.
jehuie Will this lid work with my HS2 carburetor float chamber? British Motor Corp 4
jehuie Wanted HS2 carburetor float chamber cover wanted Spridgets Classified 0
eschneider Spitfire Float height - '64 spitfire w/ dual HS2 Triumph 1
TulsaFred Float bowl to jet connection leak on HS2 Spridgets 8
BugeyeNJ58 Carb leaking HS2 at bottom of float chamber Spridgets 21
HAN8L1965 Float Removal-SU HS2 Spridgets 5
pbraun Single HS2 on an 850 Mini Moke acting odd British Motor Corp 10
jehuie HS2 carburetor question… now with video! British Motor Corp 20
Rut HS2 questions Spridgets 9
R SU HS2 rebuilds Spridgets 3
SD Bugeye HS2 interconnecting SS Braided fuel hose Spridgets 7
TomMull Post-War Other SU HS2 caburetor question Triumph 9
sim HS2 Rebuild ? Spridgets 8
AN5Sprite What Needle In Your HS2? Spridgets 3
D K&N RU-4410 on SU HS2's Spridgets 37
J Getting HS2 carb jet out Spridgets 11
T HS2 needles Spridgets 1
histerical Looking for some HS2 parts Spridgets 5
RichBall HS2 and HS4 measurment Spridgets 7
Gundy HS2 customs Spridgets 8
TexasSprite Rebushing HS2 Carb throttle shafts Spridgets 7
RickB Air cleaners for HS2 carbs? Spridgets 33
C Single HS4 vs pair of HS2 on a 1275? Spridgets 21
John Moore HS2 Stub Stacks Spridgets 0
T HS2 for 1275, right? Spridgets 7
pakiwi HS2 - Carb Issue Spridgets 3
mccalebr Eye candy - Hap's HS2 carbs Spridgets 20
Hap Waldrop HS2 velocity stacks Spridgets 37
TexasSprite HS2 Carbs Spridgets 8
58Custom SU HS2 Piston assy movement-- question Spridgets 20
Luke_Healey HS2 question Spridgets 20
Atrus Carb velocity stacks - are these HS2 or HS4? Spridgets 2
Luke_Healey SU HS2 needle variation question Spridgets 11
ChrisS HS2's flooding in turns Racing 5
ChrisS HS2's flooding in turns Spridgets 14
S HS2 SU dual carb throttle/choke linkage Spridgets 10
middleagecrazy HS2 floats Spridgets 9
drooartz HS2 on a 948 Spridgets 3
Atrus HS2 jet needles Spridgets 4
Atrus [2] HS2 vs [1] HS4 Spridgets 10
M Need to replace fast idle screws for '74 midg. HS2 Spridgets 1
Woodie HS2's and apologies Spridgets 16
Woodie hs2's slight hesitation under load Spridgets 40
Woodie hs2 & vac to dizzy - urgent - car apart in drivewy Spridgets 11
SilentUnicorn hs2 problem Spridgets 7
A T-Series Switch HS2's for HS4's ??? MG 3
C How to check for leaks at throttle shafts? [dual HS2's] Triumph 14
C HS2's...big ole' flat spot! Maybe I need to just pay someone. Triumph 27
D HS2's on a 1500...good, bad or ugly????? MG 17
nathandarby67 WANTED: S.U. HS2 Dashpots [Midget 1275] MG 3
