Gearbox Oil
Lin
I use Redline MT90 in my Toyota 5 speed gearbox and I have been happy with it. I am going to drain and refill the gearbox in the near future and plan to use Redline once again. I have heard some good things about a product called Syncro Shift II, SAE 75W-80. I just wondered if anyone knew of it and had experience with using it? I am not likely to change but I am just curious.
Anyone?
Lin
I put it in the Getrag MT-82 6-speed gearbox in my Mustang GT, per the recommendation of all the professional mechanics on the forums (/s). These gearboxes don't have a good reputation, being assembled in China, but also because of a crappy linkage design--if I've got this right, the shifter is bolted to the floor pan, not directly to the gearbox itself--and to plastic-tipped shift forks. There are lots of stories of 'blown' transmissions, although later versions, like the one in my Mustang, are said to be somewhat improved. Note some Mustang owners aren't known for being particularly careful with their equipment, but I generally treat mine well coming from the MOWOG world. TBH, I didn't notice much, if any, change in the behavior of the gearbox with the SSII; in my previous Mustang I put Royal Purple Synchromax in and I did think it improved smoothness somewhat and made 3rd gear a little less notchy (and some new Mustang owners have installed it).
I don't think you can go wrong with any name brand full synthetic in a gearbox, but I wouldn't expect a 'transformation.' I do think the MT-90 I put in both my Healeys improved shifting smoothness and OD engagement lag; but I can't imagine the SS making a huge improvement over the Redline (but let us know if it does). BG is supposedly a 'veteran owned' business, if that matters to you.
Cappy
Anyone?
Lin
View attachment 64947 View attachment 64948
I just purchased a Austin Healey with Toyota 5 speed. How do you change gear oil?
dougie
This should give you the information needed.
John Turney
Came across this transmission guy again: GL4 and GL5 Oils. The first 11 minutes is about a transmission he received that had been destroyed due to lack of oil. At about 11 minutes in he starts talking about the different types of oils, does some viscosity experiments and has some recommendations for different brands..
C Gearbox oil British Motor Corp 3
S Add ZDDP to gearbox oil? Austin Healey 29
BN6_2197 How regular should I change the gearbox oil? Austin Healey 5
R Gearbox and Overdrive Oil Level Austin Healey 18
ckeithjordan TR2/3/3A Gearbox Oil Improvement Triumph 7
D gearbox and OD oil drips Austin Healey 23
B TR2/3/3A Gearbox/OD oil Triumph 12
S TR2/3/3A TR3 Gearbox Dipstick Question on oil level Triumph 18
G Gearbox and overdrive oil change Austin Healey 15
S TR4/4A What kind of oil in overdrive gearbox? Triumph 5
gbtr6 General Tech What oil to use in the gearbox, not rebuilt. Triumph 9
C 3000 gearbox oil Austin Healey 4
K TR2/3/3A 70/90 Gearbox oil and Synchros degrading? Triumph 5
Lukens Best gearbox oil... with overdrive? Triumph 16
P Engine & Gearbox Oil Austin Healey 3
memphis Gearbox Oil Seal Austin Healey 9
memphis Gearbox Oil Austin Healey 15
MadRiver Multi-grade oil in gearbox? Austin Healey 2
mgnewbie Speedi-sleeve for the gearbox rear oil seal MG 7
mgnewbie Oil dripping from gearbox MG 5
nicko oil in gearbox Austin Healey 10
V Oil capacity of Datsun gearbox Spridgets 1
V Datsun gearbox: what kind of oil do you use? Spridgets 10
A Vexing gearbox oil leak Austin Healey 5
C Need info on gearbox and rear end oil for midget Spridgets 5
dklawson Spitfire Spitfire - Gearbox & Oil Pressure? Triumph 17
R Gearbox oil 100/6 Austin Healey 5
H MGB-GT Where is the gearbox oil filler plug on a 67 GT? MG 3
D Gearbox Oil Lotus 7
OregonTR4A Adding gear oil to the gearbox? Triumph 8
R gearbox identification help & required gearbox oil Spridgets 4
HEALEYJAG BN1 Gearbox oil Austin Healey 9
J Gearbox front oil seal Spridgets 8
Wana Gearbox and differential oil change Austin Healey 8
B gearbox oil Triumph 8
mylillooker Gearbox Oil/Fluid/Grease Spridgets 6
S Oil change in Gearbox & overdrive - extra parts ? Austin Healey 4
Woodie gearbox oil Spridgets 13
C Gearbox Oil leak? MG 10
G Gearbox oil leak? MG 3
dkj313 76 gearbox oil MG 3
DerekJ Gearbox oil level and over-filling Austin Healey 11
Z Gearbox oil and other notes by chris dimmock Austin Healey 2
B Wedge TR8 Gearbox Oil Triumph 5
sparkydave Gearbox oil question Spridgets 4
S MG Midget 1275 Gearbox Oil - Help Needed MG 3
TNMGB Checking/adding gearbox oil?? MG 34
Geo Hahn TR6 How to change gearbox oil in TR6 Triumph 11
S gearbox oil Spridgets 5
J Gearbox Oil Fill? MG 16
