Flattening Valve Covers, Oil Sumps, Timing Covers
PatGalvin
As you all know, these items get overtorqued by previous owners and we need to flatten them out so that our gaskets seal better. Does anyone have any special tools or experience that they use to flatten out the areas on these items where the previous overtightening has created distortion or dimples? It doesn't seem as easy as a few hammer taps and I'd like not to trash them with my overzealous hammering.
Thanks for any ideas.
Pat
TR3driver
Great Pumpkin - R.I.P
I don't have anything 'special', just a cheap set of body hammers & dollys somewhat similar to https://www.harborfreight.com/8-piece-hammer-and-dolly-set-46779.html (although I found mine for $20 at a swap meet) and the bench vise. Last time I was doing a timing cover, it seemed simpler to clamp the dolly in the vise (using soft jaws or some wood to protect the dolly's finish) so I could hold the cover with one hand and hammer with the other.
The hammering should be somewhere between firm and love taps, you don't want to do any bashing. Takes a bit of practice, so start with the taps and increase the force until you are just barely moving the metal with each blow. It's best if you can get the dolly to bridge any low spots (so you can beat on them from the other side), but working "off the edge" of the dolly will do, too.
Try YouTube for some how-to videos.
TR3driver
Hmm, I should probably point out that body hammers are different than most other hammers. Body hammers are not hardened (hence can be damaged by hammering nails, etc.), and the faces are perfectly flat (at least through the center) while most hammers have some crown to the face.
Using a crowned hammer is a bad idea, as it will tend to stretch the metal and make it impossible to get flat.
TR3TR6
Once you get your valve cover flatten out you might want to use one of those synthetic rubber gaskets on it. You won't have to tighten it down like you do with the cork gaskets there won't be any more leaking problems and you can pull the valve cover off as much as you want and it will reseal everytime. It costs more, but well worth it. I have them on both my TR3A and TR6. After I rebuilt the TR3 engine I had to readajust the valves, no leaking problems from the valve cover.
K TR2/3/3A Further toTR3 "flattening out at 80"..... Triumph 2
DNK Header Flattening Triumph 20
TomMull Valve lash Lotus 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
sim looking for 2 valve spring kippers for a 948 Spridgets 3
R Valve Drain Pipe Austin Healey 13
R T-Series Valve gap for an MGTD 1953. MG 5
6 Valve Oil Seals Spridgets 10
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
P TVR Big Valve 4.3 TVR 0
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
J MGB BRAKE VALVE ? MG 11
jehuie PCV valve explanation? British Motor Corp 5
R 3000 Heater Valve Austin Healey 4
T TR2/3/3A valve springs Triumph 15
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
T TR2/3/3A valve guides and piston clearance Triumph 6
kodpkd Valve Cover Gasket - Don't do this! Austin Healey 14
KVH General Tech Heater control valve/cable Triumph 1
G Valve Train Lubrication Austin Healey 1
KVH General Tech Valve Timing--No Marks Triumph 20
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
D Water Valve Connection Austin Healey 4
R TR2/3/3A Rule 9 Valve Adjustment Triumph 8
RJS General TR Lever Shock - HD Shock Valve Triumph 2
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
M TR5/TR250 Bypass valve Triumph 27
I Bugeye valve rebuild suggestions Spridgets 8
G Valve Cover Gasket Silicone Adhesive Austin Healey 5
J Oil Pressure Relief Valve Austin Healey 3
K TR2/3/3A An alternate valve adjusting sequence? Triumph 3
K TR2/3/3A Camshafts and Valve Settings Conundrum? Triumph 7
charlie74 TR6 ā€˜74 valve springs Triumph 0
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
M TR6 PDWA valve Triumph 6
M Ray Juncal Valve Covers Austin Healey 5
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
BillyB62 TR2/3/3A Anyone seen a valve cover like this Triumph 0
alexisrexx TR6 Oil Sludge in Valve Cover - Normal? Triumph 16
K TR2/3/3A Brake Restrictor valve? Triumph 9
Lin Heater water valve question Spridgets 2
D MGB MBG valve clearance MG 1
K TR2/3/3A Finding valve lash with cam specs? Triumph 8
A T-Series MGTD oil pump bypass valve MG 0
S Price check on TR3A valve cover Triumph Classifieds 0
H BJ8 Heater Valve/Control Tap Austin Healey 3
J Wanted ZS 175 CD-2 Air Valve Triumph Classifieds 0
G Valve adjustment and easiest way set cam position Austin Healey 15
CharlesBN1 Uprated or 'umbrella' valve stem oil seals for BN1 Austin Healey 2
