TR5/TR250 excessive oil usage on tr250
vrod
since my last engine rebuild, my tr has been using too much oil (about 1 quart every 200 miles). I believe it is either because the valve guides do not have any seals (which is of stock configuration) bronze guides where installed during the rebuild and I was told adding seals would deprive the guides of much needed lubrication. the other cause could possibly be coming from the added on after market, oil feed line. I have read that this causes excessive oil usage.
mailbox
That is a bit exessive. Whoever told you not to put seals on the valve guides, in my opinion, is wrong. Yes, the guides do need oil, but not that much. Does blue smoke come out the tailpipe when you start it up? Thats a sign of losing oil thru the guides. That still seems like alot of oil for valve guides leaking. I think you have other problems. Oh well, there's my .02 worth. /ubbthreads/images/graemlins/grin.gif
Stinky
Could'nt you temporarily block off that oil feed line,...then see if that cures the oil consumption problem?
At least that seems lie an easy way to find out if that oil feed line is causing any problems.
Geo Hahn
Disconnecting the oil feed line is a good idea as that is a likely culprit. Other than that I would look into where is th e oil going & when. Color and timing of tailpipe smoke is a clue, some leaks are obvious but others occur only at certain RPMs, blow-by can cause oil to be sucked thru the carbs or pushed out elsewhere.
A quart in 200 miles should be pretty noticeable.
Dave Russell
Yoda - R.I.P
I agree with George, Stinky, & Mailbox on the extra oil line & the valve stem seals. Flooding the top end, especially without seals can let a lot of oil in.
M Bn2 excessive oil pressure Austin Healey 4
R TR4/4A TR4A Excessive oil consumption-PCV valve or ?? Triumph 9
R Excessive oil pressure problem Austin Healey 17
F Excessive Brake Pedal Travel Austin Healey 3
Gliderman8 TR6 Excessive reading on volt gauge Triumph 17
LAW75 Bonnet Excessive Sway Austin Healey 6
D TR2/3/3A Excessive cranking before it starts. Triumph 47
R TR4/4A Excessive body rattles Triumph 5
Tinkerman TR2/3/3A 1960 TR 3A excessive 3" to 4" steering wheel play. Triumph 2
H excessive wheel bearing shims? Austin Healey 11
RJS Excessive Brake Dust? Triumph 7
Johnny What does "excessive brake fluid pressure" mean? Austin Healey 21
J Excessive exhaust smoke Austin Healey 12
Hegg Excessive Fuel Pressure - how do I stop the leak? Triumph 8
D T-Series MGTD Oil Leak? MG 1
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
G Right-Side Shock Weeping Oil Austin Healey 1
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
Bayless What oil for Datsun 5 speed? Spridgets 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
K TR2/3/3A Old school penetrating oil? Triumph 24
nevets Spin-On Oil Filter Adaptor Austin Healey 12
D Overdrive Stops Working After Oil Change Austin Healey 26
Celtic 77 General MG Lever shock oil refiller MG 0
I MGB Sprung an (oil) Leak! MG 2
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
WHT Oil Sump Question For Dougie Austin Healey 0
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
A TR6 spin on oil filter for tr6 Triumph 4
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
