Cam shaft
Trevor Triumph
As summer nears and I have time again, my wife's Spitfire is calling... We're rebuilding the 1500 engine and have installed high compression pistons, secured a 4 into 1 header, bought a twin carb manifold and two S.U. carb puzzles. I don't know what is in the car now... actually the cam is in a box on the garage floor... I figure since the engine had the low compression pistons, the single Stromberg carb, and the cast exhaust manifold, the cam is stock as well. Now my questions, do I want to add a hotter cam? Is there a way to determine if the old cam is stock? We don't intend to race the car but we would use the car to travel to Triumphest, Las Cruses NM, and such; in other words hundreds of miles often on the Interstate. Any suggestions? (Our current Spitfire, Trevor, a MkI screams at Interstate speeds and the automatic hill detector works very well: forty-five MPH up the hill into Flagstaff AZ is quite scary.) T.T.
Bob Claffie
Trevor; Based on Spitfire experiences quite some time ago and using fuzzy math, my best guess that your 1500 will be turning around 4500 at 75 mph. It doesn't make any difference which cam you use- speed equals revs. If you have OD that would chop a few hundred revs off my guestimate. (My FP SCCA Spitfire would just about hit 100 at 7200 rpms with a 4.55/1 rear end gear, no OD). Bob
MDCanaday
Trevor, the best thing to do is contact integeral cams they can re-grind your cam to whatever you want.Also have the old lifters re-faced, much cheaper than AM lifters & much superior(many bad AM lifters out there). You might also want to invest in some balancing of the crank& rods, that way at 4500 you and your fillings wont part ways.
MD(mad dog)
S TR2/3/3A Replacing the cam shaft Triumph 27
Walter74 Kent AH4 cam shaft Austin Healey 18
J General TR Cam shaft upgrade????? Triumph 3
J TR2/3/3A Triumph TR3 cam shaft measurement Triumph 2
T Spitfire Cam shaft Triumph 3
T Cam shaft end float Triumph 18
2wrench TR6 '74 TR6 Stubborn cam shaft Triumph 8
2wrench Cam shaft early demise Triumph 23
LearJeff Aligning Cam shaft and Crank...Suggestions? Triumph 19
R Cam shaft areas Triumph 8
J TR 4 Norris Cam 342S Spec Sheet Racing 1
PAUL161 T-Series Crane Cam MG 0
D TR6 Gp 2 cam, head shaved ,shorter pushrods, with a rough idle Triumph 10
M MGA RHD twin cam steering pinion MG 0
D Cam Timing question. Spridgets 11
TomMull TR2/3/3A Steering Box Cam or Worm Triumph 18
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
Kolecki TR2/3/3A engine assembly cam timing issue Triumph 8
K TR2/3/3A Finding valve lash with cam specs? Triumph 8
Got_All_4 TR5/TR250 Cam and Lifter Problems Triumph 13
B Installing cam bearings 1275, can I do it? Spridgets 1
B Anyone have a Europa Twin Cam for sale? Lotus 6
J TR2/3/3A Confirming Cam Set Up Triumph 5
G Valve adjustment and easiest way set cam position Austin Healey 15
S TR6 Quiz .... What cam is this? Triumph 0
B TR4/4A Front cam bearing Triumph 8
B TR4/4A Performance cam Triumph 24
K TR2/3/3A More pics of Kast Cam Triumph 4
K TR2/3/3A Kast f cam...301466 Triumph 5
L TR2/3/3A Cam follower rotation Triumph 5
Csarneson BN4 Cam Gear Install Austin Healey 3
N Best cam choice??? Spridgets 5
KVH TR4/4A I Replaced the Cam Bearings Triumph 19
M Wanted TR3/4 Cam Bearings Triumph Classifieds 1
R General Tech Cam measurement. Triumph 6
Got_All_4 TR6 Cam selection decision time could use your thoughts Triumph 2
M TR2/3/3A Cam Bearing Tool Dimensions Triumph 16
W Cam gear position BJ8 Austin Healey 11
R TR6 Cam choices? Triumph 23
T TR4/4A Core Plug - Cam Rear change Triumph 7
D cam bearings Austin Healey 23
KVH General Tech Engine Rebuild: Failed at Cam Break-in Triumph 11
E TR6 Some cam questions Triumph 9
steveg Denis Welch mild cam Austin Healey 9
B Twin OH Cam for the BIG Healeys Austin Healey 15
K TR2/3/3A Street cam again and Valve gap? Triumph 6
K TR2/3/3A Mild street cam and Idle? Triumph 13
J MGB MGB cam, gear? MG 3
K TR4/4A Performance Cam=Broken Rings??? Triumph 9
