LearJeff
Everything was complete. My 1974 TR6 Total Rebuild Project (body off, from the ground up) was finally done. There she sat this past Sunday (June 11, 2006) on all four shiny new wheels. Our crowning acheivement, the 4-wheel discs proudly peeking from behind those sweet 16" Panasports! The first scheduled test drive was yesterday (Monday) morning. I couldn't be there for it but stopped by after lunch only to discover, much to my dismay, that Steve had removed the hood, the radiator, the front crossmember brace, the steering rack, the valve cover, the fan and pulley assembly and the timing chain cover...this didn't look good.
Steve reported that during the test drive, when put under any kind of load at all, the engine spit and sputtered, coughed and burped and basically all but gave up the ghost. Of course, we had idled the engine several times in the shop prior to the first test drive and it ran just fine. Even brief runs to 3500 and 4000 RPM sounded smooth and powerful. And remember, we're talking about a complete teardown and re-build with mostly new innards here. Steve's buddies next door at the engine shop did all the work and they have always done excellent work for him in the past. Upon closer examination of the timing marks (after removing the previously mentioned stuff) it appears (possibly?) that the cam shaft and crank were not properly installed/aligned at the shop. The Haynes Manual is mostly pathetic regarding this topic, with its cruddy pictures and ambiguous text.
A couple of folks at Moss were very helpful yesterday, but I was hoping someone here might be able to refer me to a good printed resource or offer up their own words of wisdom. Thanks!
