Got_All_4
Got an Idea what I want to do but what would you do? Had my head milled, new hardened exhaust seats installed, going to do a light port job and port match the exhaust and intake manifolds.
Head came out to be 3.438" which is a bit over 9:1 compression with standard bore. I figure 9.125:1. Getting ready to send my cam to Delta cam shaft and looking at their 250 Sport cam and standard OEM lift roller rockers(146:1). My other option is to use the original Triumph cam with a step up in lift to 155:1 roller rockers. Just want a mild upgrade in horse power say around 115 to 120, good idle and reliability.
These are the specks on the Delta cam grind I'm looking at. Dur int 250 Dur exh 254, int opens 17, closes 53, exh opens 60, closes 14, cam rise .255 L/C 108 deg, Lash int & Exh .014
