Wires stuck in stator tube
TRJohn
Well fifty years of road gunge, rust and who knows what else have caused the wires to become totally jammed in the stator tube of my TR2. Any idea how to get them out????? I've exhausted all avenues of brute force and sprayed a whole can of lube into the thing. Stuck fast.
Andrew Mace
Hmmm, any way you can pull them back down? I'll assume you're trying to pull out the wires and control head from the steering wheel? Most of these will have had the "bullet" connectors on the bottom, and it's virtually impossible to pull the group of four wires up if the bullet connectors aren't "staggered" somewhat.
It might be best to (ouch) cut or otherwise undo the wires at the control head and then find some way to "ram" what's left down? I'm going here on the assumption that you'll want to replace the wires with new.
BOXoROCKS
Pull the one with the most slack,it should be the closest to the top.If not braze the ends of brazing rod together,clean the joint and push backward down the tube against the wires as you pull up on ONE wire.
T TR2/3/3A Stator tube, wires stuck Triumph 15
C MGB New plug wires and distributor cap MG 10
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
K TR2/3/3A Distributor internal wires? Triumph 5
C Spitfire Mystery wires - Spit, left near distributor Triumph 2
K TR2/3/3A The two wires that go to the brake light stop switch junction......... Triumph 1
B TR4/4A Too Many Wires? Wiper Motor Triumph 9
R Ground wires under dash Spridgets 5
K TR2/3/3A Testing spark plug wires..... Triumph 11
steveg TR6 TDC - Position of rotor and wires Triumph 4
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
AUSMHLY Spark plug wires 7mm or 8mm Austin Healey 21
longbridgehealey Spark plug wires Austin Healey 8
S TR2/3/3A those 3 white wires onto the ignition switch Triumph 3
B TR6 1970 High Back Seats for TR6 - Side bolste wires squabs neededr Triumph 3
steveg Cobalt top entry wires question Austin Healey 47
69MGC MGC What are these connection wires? MG 6
P TR6 Purple/Red wires & mystery bulbs Triumph 17
69MGC MGC Chrome Wires for my C MG 11
M TR2/3/3A Two black wires on control box E where do they g0 after alternator conversion? Triumph 9
M TR4/4A TR4 door glass spacer wires. Triumph 1
DerekJ Lighting circuit - the smoke's escaped from the wires.! Austin Healey 12
D TR6 Rats nest of wires Triumph 3
2billydavies TR2/3/3A Question about front turning blinker wires Triumph 12
Got_All_4 Wedge Tr7 windshield factory windshield wires Triumph 3
J General Tech I Need a Set of Plug Wires! Help! Triumph 14
JFS TR2/3/3A Stator Tube Wires Triumph 9
W connecting distributor wires Austin Healey 2
T TR2/3/3A Is there a good way to manage all those wires/connectors for headlights & park lights Triumph 9
R BN7 Coil Wires Austin Healey 3
matttnz TR6 Brown wires multiplying Triumph 12
KVH TR4/4A Burned Wires Under the Dash Triumph 2
O TR2/3/3A TR4 Wires to TR3 Triumph 11
Keith_M XJS 12 cylinder wires, cap, and rotor Jaguar 7
S Correct colour BJ8 Spark Plug Wires / HT Leads Austin Healey 7
drooartz MGB Which plug wires go where... MG 5
Rut MGB wires on a Midget Spridgets 6
PatGalvin TR2/3/3A TR3 tires for wires Triumph 2
B Ignition wires to use with Pertronix distibutor Austin Healey 9
richie Ignition leads/wires Triumph 8
B MGB 1978 MGB 2 wires hanging under the dash to the .. MG 4
C Tires on wires Triumph 33
M Restoring proper order to spark plug wires Triumph 36
R Ignition wires Austin Healey 5
I TR6 TR6 heater blower wires -what are these wires for? Triumph 8
wingsandwheels TR6 green plug wires, '74 Tr6 Triumph 6
JohnnyO Dist cap and plug wires Spridgets 6
A Running wires to the door ... Triumph 4
RickB Weird DPO wires heating up really hot Spridgets 16
