2billydavies
Hi guys... me again. Wiring question for you all.
Just getting the front grill on my TR3a and hooking the front turning blinkers up with the wiring.
I have 3 wires on each side going into each of the two front turning blinkers (inside the grill).
Problem is, there are only 2 screws to plug the wires into on each lamp. The colored wires go into these screws, which I clearly marked when taking it all apart before my engine rebuild.
However, on each side, there is a single black wire that appears to go "nowhere." For the life of me I can't remember where it went when I took it apart.... clearly didn't label it because I would easily "remember" it when I put it back together, which I cannot of course.
Any idea what these two wires are and where they go? My first guess is a ground wires for each front turning blinker lamp, but they have no connectors on the ends of them and I can't find anywhere where they would have screwed down onto the frame of the car or anything. They are only so long, so just holding them and looking around with the length of the wire in hand, I can't find anywhere to put them.
I do have the ground wires for the actual headlights hooked up. I simply bolted them to one of the bolts that holds the horn down to the frame (on each side, one ground on each horn). All of the lights work fine.... even the front blinkers where this mysterious black wire is just hanging out of the wiring harness.
Thoughts? Ideas? Should I just cap it off and tuck them away?
Thanks! ~ Billy
Thanks! ~ Billy
