martx-5 said:
Is there any particular reason why you would want bias-ply tires instead of radials?? The advantages of bias-ply tires over radials is far exceeded by the advantages of radials over bias-ply.
More info here...
It's interesting that they don't address the most believable myth (IMO), that bias-ply tires don't wander as much as radials (due to stiffer sidewalls).
Also, they mention "flat spots", but neglected to mention that they are a problem only with nylon-cord tires. One of the last improvements before radial tires was the use of polyester cords rather than nylon, which among other things greatly reduced that distinctive thump-thump-thump on a cold morning. (Not that it was ever a problem, it quickly went away, but it was noticeable.)
And maybe they do exist, but I've never seen a radial tire that didn't look a bit under-inflated, compared to a bias ply with the same pressure.
All that said, I still wouldn't use a bias-ply if a radial was available.
