Tires for BT7
esussman
I have Redline 165R15/86T steel belted radial tires on my Healey. Can't find any manufacturer name other the "Metric". They came with the car 16 years ago and still look new. No signs of dry rot but thinking it might be better to replace them due to age. Good idea?
Very hard to find Redline 165R15 radials although Coker has 185R15s. Will they work or should I stick with the original size?
Thanks,
Eric
DerekJ
You should change them immediately. 16 year old tyres will be hard as rock, have next to no grip regardless of tread and may be ready to delaminate. 165 or 185 will work but if you have the original 4.5 inch rime maybe best to stick to the 165s.
E
esussman
Thanks for your reply. Rims not original. They are 72 spoke chrome rims. Outer diameter (lip to lip) is 16 inches. Will 185s fit?
Thanks,
Eric
Bob McElwee
My guess is if the tires are 16 years old they probably have tubes in them. You would want to replace them also.
E
esussman
Found Vredestein 165r15's reasonably priced at Summit. Guess I'll go with those and the tubes to be safe.
Thanks,
Eric
Did they need tubes?
Thanks,
Eric
If they're unsealed wire wheels, yes; if not, no. BTW, your rims are most likely 15"; I think you measure from base of bead to base of bead, but I'm not sure (never heard of Big Healeys with anything other than 15" rims, but not impossible).
Jack T
Thanks,
Eric
The dimension to check is rim width (inside bead to inside bead) to determine if a wider tire will work. If your wheels are 72 spokes, they are probably at least 5" wide and will handle 185 tires no problem. The wheel should be marked somewhere with something like "5J15", '5' being the width, '15' the diameter. I think the original Healey wheels were 4" or 4.5" wide, and you could get a bit of 'wallowing' in the turns if too wide a tire is fitted.
E
esussman
Thanks for the info Jack. Couldn't find any marking on the rims as mounted but they are definitely not 4 inches by my tape measure. At least 5" bead to bead. Only question left is to decide on the 165 Vredesteins or Coker's redline 185s. The redlines on my Healey now look really cool as the body color is resale red. Just don't know about the quality of Coker's product.
Jack T
There are Coker red lines on the TR6 I bought. Haven't driven it a lot, but the tires are adequate. Should work fine with a Healey. The 185 tire may increase the steering effort a bit, but will fill the wheel openings more than a 165.
Jack
E
esussman
Just got the redline Coker 185R15s. Waiting on the tubes. Uninflated the 185s tires appear to have a much larger circumference than my 165s still on my Healey. Sure hope they will fit.
dcarlg
I'm sure you will be very pleased with 185s.
Try the Torrington bearings atop the trunion if you want to decrease steering effort. I also installed the offset trunion bush to change camber to zero.
E
esussman
After confirming on their website, the Coker 185s are 27" diameter. That's nearly the size of the wheel well. Really concerned now.
E
esussman
i think that's because most 165s and 185s are 25.5" in diameter. These seem quite a bit larger. Still researching.
E
esussman
Hendrix wire wheels confirmed they will not fit. Suggested DB tires or the Vredesteins. Oh well, too late smart.
Jack T
I stood the wheel from my Healey with a 165-15 Michelin on it next to the Coker red line on the TR6, and the Coker tire was 1" taller. Granted, there was no load on the Healey tire, but considering how much empty space there is in the Healey's wheel wells with the 165 it's hard to believe the red line won't work.
B Tires - 185-65R15 for BT7 or BJ7? Austin Healey 19
B Wheels and Tires Selection Austin Healey 10
Lutz Kramer Tires Squeaking on Curves Austin Healey 4
Got_All_4 For Sale 2 Vredestein Sprint + S80 Tires 165 R 15 86S Triumph Classifieds 0
red57 Michelin XAS Tires Austin Healey 38
D Vredestein Tires Austin Healey 11
tinman58 TR2/3/3A New Tires Triumph 10
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
luke44 TR2/3/3A TR3 inside the tires track dimension Triumph 5
drooartz New wheels and tires for Penny Spridgets 16
TR6Canuck TR6 Wire spoke rims to fit Michelin Red Line Tires on TR6 Triumph 12
johnrip Wedge tr7 tires Triumph 1
vette North East Tires Austin Healey 16
F TR6 Wheels and tires Triumph 10
johnrip Wedge Tires for TR7 stock alloy wheels Triumph 1
S TR2/3/3A Tires Triumph 19
B Tubes in radial tires on wire wheels - what do you do? Austin Healey 27
69MGC MGC What size tires will fit nicely MG 2
danstr6 For Sale Redline tires for sale Triumph Classifieds 0
Jayplum TR2/3/3A Wheels, tires, hubs and axles Triumph 22
edkap2002 TR6 wider tires Triumph 9
pbraun Ideas on tires for Bugeye with 13x6" wheels Spridgets 3
Bayless What tires for '67 Sprite? Spridgets 5
CessnaTPA New Tires or Keep Old Ones Austin Healey 36
5 Sumitomo 13 inch Tires Spridgets 19
madhouse Need Dunlop 165/R15 tires Austin Healey 8
P For Sale Five 6.50-13 Bias ply US Royal Safety 800 tires for sale Spridgets Classified 0
Joe Schlosser Wheels and tires Spridgets 15
T TR2/3/3A What air pressure is recommended in my Hoosier tires? Triumph 1
I For Sale Minilite replicas with Michelin tires $400 Triumph Classifieds 16
P MGB MGB tires MG 11
B XK-120 tires Jaguar 7
aero3113 Vredstein Sprint Classic Tires Austin Healey 28
davidb TR6 TR6 tires Triumph 13
S Michelin XAS tires for my '67 Austin Healey 3000 Austin Healey 16
Jim_Gruber New Wheels and New Tires for Bugsy IV Spridgets 5
D T-Series T is for Tires MG 10
H 280i Tires TVR 7
Jim_Gruber 13" Tires - What's out there right now Spridgets 21
Basil Vredestine Tires Restoration & Tools 5
CJD TR2/3/3A Latest Tires Triumph 38
K TR6 Wheels and tires Triumph 3
tinman58 TR5/TR250 tires, hubcaps and rims for sale Triumph 0
J Heidenau tires Austin Healey 0
Michael Oritt Does anyone drive with bias-ply tires? Austin Healey 40
rjc157 TR6 tires Triumph 8
maxwedge5281 advice on tires for v8 healey Austin Healey 7
S TR6 new wheels and tires Triumph 18
R TR4/4A Nexen Tires Triumph 7
