Wheels and tires
Joe Schlosser
Who has the best deals on a set of Panasports (I know they are replicas) for a BE.
Time for new tires and the old (very old) Cosmics have had their day.
However, I do like the look and everyone else is on Panasport , old Cosmics are just corroded on the inside from 30 years of moisture.
Who does that kind of wheel restoration?
Thanks in advance
Joe Schlosser
Joe Schlosser
Brain fade here posted before complete thought.
It has been more than 10 years since I bought tires. 165 70 13.
Who is running what and what is available today??
Rut
Joe,
I bought a set of VTO Classic 8s from Hap Waldrop at Acme Speed Shop and really like them. There are not too many choices in 13” tires and a lot of people go for 14” wheels with a lower profile tire. I got my last set from Tireseasy.com.
Rut
https://www.acmespeedshop.com/wheels/
drooartz
For my street Bugeye I'm a fan of 155/80R13 -- but I'm not looking for all out performance and stickiness. My Bugeye currently has 175's on the stock steel wheels, but it's just a rolling shell at this point. I will likely go back with 155's when the restoration is done.
Joe Schlosser
Joe Schlosser
Another OOPs
Not Cosmics but look like very early BBS. I am running 5.5 X13 with a 85 mm backspace. These wheels leave me a lot of clearance with minimal spacers. none in front and 1/4' in the rear.
There are some JBW wheels on Ebay , 5 inch with 100 mm backspace that are supposed to be for Spridgets. Any one used this size wheel?
I am having a difficult time finding replacement 165 70 13 tires.
If I go up to 185X60 I am thinking they would be too wide for the 5 inch wheels but no problem with the 5.5.
There are some 175 X70 out there that might work
Thoughts are appreciated.
Joe Schlosser
Joe Schlosser
Drew
What size wheels are you using for the 175mm tires??
Jim_Gruber
Joe, i’m Running JBW 8 spoke w polished rim. I got a deal at Brexit when exchange rate went bonkers. On a 5” wheel 175 is max tire size. 185 needs a 5.5” wheel. I did need to add a 1/4” spacer up front and go with longer wheel studs but no other clearance issues. In the rear no spacer but went w longer wheel studs. Delivery from UK, 2 days via DHL airfreight to my door. Longer wheel studs and spacer from Winners Circle. A number of different wheel styles available from JBW web site.
Jim_Gruber
Tires a 175 from Walmart. And I believe 70 profile about $40 per tire with a UTOQ of 225 or so.
SD Bugeye
kumho 175 70 On my old minator wheels just mounted these about two weeks ago seem nice no issues no spacers
A 185 tire will peek out from the edge of the fender (depending on the wheel width and offset). I would definitely stay with a 175 or less. I have 185/60R14 on my bugeye using a VTO rim. I have some pretty sticky tires, but it is not a comfy ride ... although it is a heck of a lot of fun on an autocross course.
drooartz
Drew
They're on the original Bugeye steel wheels, which I think are 3.5" wide. Too much tire for those rims, they were put on by the previous owner.
Joe Schlosser
Joe Schlosser
Thanks everyone. I ordered a set of 175 Kuhmo from TR. Should not be much diff form the old 165s I have now.
I am staying with my 5.5" rims for the moment. One $$ event t a time
Gerard
Joe Schlosser
Joe Schlosser
My issue at the moment is the clearance at the front of the tire to the fender when I turn the wheel. I mounted new Kuhmo 175 70 13 on my old 5.5"rims with 80mm backspace. My spare set of ro-style rims are 5" with 100mm backspace which woul move the tire in by 20 mm which should provide clearance. This is the same width and backspace that the Panasport/MBW has.
So far it seems that no one has come up with a problem with this tire and wheel combination.
Any one wish to chime in??
Jim
What were the spacers needed for the front?? May I assume wheel clearance to the tie rod?
Joe Schlosser
Joe Schlosser
With the 175 70 13 tires the 5.5 inch has too much backspace for the front wheels to clear when turning. The steel Rostat wheels are 5" inch with 100mm backspace and would work fine but I decided to speing for new JBW minilite replicas, 5 inch with 100mm backspace.
Found a great deal on Ebay, with two day shipping from the UK.
Everything is perfect. No spacers needed at front and a full 9 turns on the standard wheel studs. I am really happy I do not need to pull the front apart to install longer studs (have a bag full of different lengths). I like extra clearance inside of the rear so I left the 1/4 spacer installed.
Any way from a bad bead on a tire to a complete set of new tires and wheels in a week
Jim_Gruber
Yes clearance for Tie Rod IIRC Been 8-9 months ago. went w longer Wheel Studs F & R.
B Wheels and Tires Selection Austin Healey 10
drooartz New wheels and tires for Penny Spridgets 16
F TR6 Wheels and tires Triumph 10
johnrip Wedge Tires for TR7 stock alloy wheels Triumph 1
B Tubes in radial tires on wire wheels - what do you do? Austin Healey 27
Jayplum TR2/3/3A Wheels, tires, hubs and axles Triumph 22
pbraun Ideas on tires for Bugeye with 13x6" wheels Spridgets 3
Jim_Gruber New Wheels and New Tires for Bugsy IV Spridgets 5
K TR6 Wheels and tires Triumph 3
S TR6 new wheels and tires Triumph 18
BN6_2197 185/80 tires on 15'' wire wheels in Germany Austin Healey 10
O TR4/4A Will these tires/wheels work on my 1966 TR4a, IRS? Triumph 19
RJS TR4/4A Questions: new tires on old wire wheels Triumph 10
tr7andtvr Wedge Wheels and Tires? Triumph 13
N What size wheels and tires for flared fenders? Spridgets 7
58Custom Who can mount tires & balance wire wheels in LA? Spridgets 5
Rut New wheels arrived, which tires? Spridgets 3
M Use of Tubeless Tires for Early Sedan Wheels Jaguar 0
af3683 Changing tires on Original TR 3 Wire Wheels Triumph 4
Hoosier MGB Nearly new Tires plus wheels for MGB MG 8
M wheels, tires, and tubes Triumph 8
J Inexpensive way to ship tires/wheels Triumph 10
Tabcon Wheels-Tires-and Bell Bottoms Triumph 15
KVH TR4/4A Tires and Wheels on a TR4--A follow Up Triumph 9
pjsmetana Spitfire Spitfire, Wire Wheels, White Wall Tires... Triumph 26
T what max size tires & wheels fit a tr4,tr4a,tr250? Racing 3
Y TR4/4A '64 TR-4 tires w/ wire wheels Triumph 6
M europa,wider,lower,tires,wheels Lotus 0
A Tires and Wheels? Austin Healey 2
mjobrien New Tires and Wheels for BN1 Austin Healey 8
C How do you ship wheels and tires? Triumph 10
Baz Wire wheels, tires and tubes.... Restoration & Tools 7
WidespreadPanic New wheels & Tires Triumph 24
Y TR4/4A TR-4 Wire Wheels & Tires Triumph 6
S Wheels and tires for a BJ8 Austin Healey 15
D TR2/3/3A Free TR3 wheels, tires, hub caps Triumph 4
jlaird Something else to think about, Wheels and tires. Spridgets 1
R TR4/4A whitewall tires on spoke wheels TR4A? Triumph 8
PAUL161 MGB MGB Wire Wheels & Tires MG 7
mrstinson Wheels and Tires Spridgets 13
martx-5 Wire Wheels and New Tires Triumph 5
J Wedge 14" wheels, tires for TR7 Triumph 0
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M For Sale Vintage Modular HTN 3 Piece Racing Wheels 13" Triumph Classifieds 0
F MGB-GT what do these wheels go to MG 1
CARSINC My Spyder-Mite Gets Wheels Spridgets 9
K TR2/3/3A American Racing Slot Wheels Triumph 0
R For Sale FS: Revolution 5 Spoke Wheels (Triumph) Other British Classifieds 4
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
