Ignition wires
rangerrik
Wondering if the ignition wire numbers represent the firing order or are they just numbered 1-6 front to rear.
Thanks
R
rangerrik
I didn't do a very good job of asking the question. I'm putting new wires on with numbers and the old ones wern't numbered. So I wasn't sure if the numbers should represent the firing order or should just be 1-6 front to rear.
Thanks
elrey
Each wire's number should correspond with the number of the cylinder it services.
shorn
Or in other words, the most forward cylinder will have the #1 spark plug wire which would go on the distributor cap where the rotor points to that position when the #1 cylinder is top dead center. The # 2 or second inline cylinder wire goes on the dist cap in a position four away from the #1 wire (counter clockwise direction) etc. etc. according to the firing order. The position right next to #1 on the dist cap is where spark plug wire 5 would go.
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
S TR2/3/3A those 3 white wires onto the ignition switch Triumph 3
B Ignition wires to use with Pertronix distibutor Austin Healey 9
richie Ignition leads/wires Triumph 8
M Bumblebee ignition wires Triumph 23
V TR6 TR6 Ignition Wires Triumph 14
longbridgehealey ignition wires Spridgets 9
H Plug wires for electronic ignition Austin Healey 18
P proper ignition wires for 1098 CG...??? Austin Healey 2
Ed_K Ignition wires and radio noise Austin Healey 0
drooartz Connecting ignition wires Spridgets 10
R Ignition Failure Austin Healey 12
R Bugeye ignition switch Spridgets 2
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
T 100 BN2 Possible Ignition Issue Austin Healey 10
Cokerair TR4/4A Fried Ignition Coil Triumph 18
R Wanted Bugeye ignition switch Spridgets Classified 2
J TR2/3/3A Red ignition light stays on Triumph 7
F Hot Ignition Coil Austin Healey 6
J Ignition Key Malfunction Austin Healey 6
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
SherpaPilot TR6 Ignition Switch Question Triumph 13
PAUL161 T-Series MGTF Ignition Key MG 7
P TR2/3/3A ignition switch smoking Triumph 12
rgfrey BN4 Ignition/Turn Indicator Light Austin Healey 7
PAUL161 T-Series Points Triggering Electronic Ignition MG 5
W Healey BN1 Ignition Light Austin Healey 8
C TR6 Ignition Switch for 1972 TR6 Triumph 1
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
E Ignition Timing Austin Healey 14
T TR6 Continuous Starting and Ignition Issues Triumph 6
TRickster6 MGB electronic ignition on '73 MGB MG 1
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
jlaird MGB ignition switch MG 2
algot1901 Electronic Ignition for 1950 Prefect 1172cc Eng Other British Cars 10
Lin Ignition timing question Spridgets 2
H MGB 1980 mgb no power from ignition switch MG 23
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
Lin Crane or Fast XR700 Electronic Ignition Austin Healey 4
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
PAUL161 T-Series MGTF Xpeg Ignition Coil MG 22
M Tachometer not working following ignition upgrade Austin Healey 10
Cappy Ignition Warning Light Austin Healey 6
longbridgehealey Bugeye ignition switch Spridgets 4
J Ignition Key Cylinder Removal Austin Healey 3
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
