Hey there Guest! If you enjoy BCF and find our forum a useful resource, if you appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please consider supporting with an "optional" low-cost annual subscription.
Has anyone used the viton valve stem oil seals that were advertised on Ebay awhile back and does anyone have the email address of the person that was selling them?
I think my valve guides are worn slightly. I get some smoke on start up after sitting awhile. Mine is a 72 I think it has single springs. If it is the single spring,and I have to check that I can use the bonnet type. I am trying to find a source.
You will have to pull the head to install the new guides, so that is the time to have the machine shop (or you, because I know your machining skills) cut down the guide tops to allow for the seals to fit over the top.
I found the oil pan you wanted if you still need it.
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
