Valve lash - Is this how it is done?
Ray Brandes
Member
We are rebuilding a 907 engine for a Jensen-Healey. We are having the valves re-ground.
We are eliminating the paper gaskets under the cam towers and will use the 515 sealant.
Both of these things will reduce the thickness of the shims.
I will make some temporary shims, a bit undersized, and measure the lash.
Based on these measurements I will grind the original shims for the proper lash.
Regards, Ray
TomMull
You make it sound easy. If you have the skills and tooling to make the shims, that will help. Also make a good chart of all your measurements. I've not done a Lotus but in the past did a Fiat and a SOHC Triumph TR7 (Also read that the TR7 shims are the same size as the Lotus). Both took me several tries to get even reasonably satisfactory clearances. The more accurate, orderly and methodical you can be (I'm none of those) the better the results.
You might find this interesting too:
https://www.jensenhealey.com/forums/view_topic.php?id=746&forum_id=2&page=3
Tom
Platinum
Done many, including my own three Lotus'. Shims are available at Dave Bean Engineering (NFI). I've a set made from brass and cut to 0.040" to use as a "base" reading and do the math to come up with proper clearances. A felt-tip marker is useful to write the measurements on the lip of the head adjacent to each pot.
BTW: The shims are hardened, need to be lapped to make 'em thinner. A real chore to be accurate with those little buggers. Best to get the proper thickness from a supplier.
R
Ray Brandes
Member
Thanks guys! I have a surface grinder to set the shims to the correct thickness. I made a steel set of .085" for a base and went from there.
I kept putting in feeler gauges going up .001" at a time until one wouldn't go. I recorded that value and the one under it that went.
I used these measurements in a spread sheet to get the new shim values.
Regards, Ray
PS: Made urethane tail light gaskets for my BMW 700. Turned out great!
E
Esprit2
Ray,
As with your points gap question, I'm too late to the party to be helpful, but...
The shims are case hardened, not hardened all the way through. If you grind them much thinner, the case hardened layer will end up too thin. A couple of thousandths is okay, but if you plan to make up for both deleting the gasket and grinding the valves, I fear the shims will have to be ground too much, and the hard layer will become too thin.
Deleting the cam carrier gasket also involves cutting a counterbore around the front oil passage/ dowel pin, and installing an O-ring there... one per cam carrier. If you know all of that, then you're good. If not, ping me and I can give you the dimensions for the C-bore and O-ring.
Basically, you're on the right track, just watch those details. The clearances close up with wear, so always shim to the top of the clearance range. That will give the longest mileage interval before the job has to be re-done.
0.005" - 0.007" Intake... Target 0.0065" dry.
0.010" - 0.012" Exhaust, Target 0.0115" dry.
The anaerobic sealants have a half-thousandth film thickness. So when the Loctite 515 or 518 is added during final assembly, the film thickness will 'float' the head up another half-thousandth, and give a final 0.007" Intake, and 0.012" Exhaust.
515 & 518 are both good. But 518 is more fluid, easier to spread (paint it on with a flux brush), while simultaneously better at gap filling. Given a choice, I use 518. But if you have 515 it works well... it's just more difficult to apply.
Regards,
Tim Engel
a Lotus fan
TomMull Valve lash Lotus 0
K TR2/3/3A Finding valve lash with cam specs? Triumph 8
mgedit TR2/3/3A Setting Valve Lash Triumph 14
M 1275 valve lash adjustment "shade tree" Spridgets 10
wkilleffer MGB Questions about timing and valve lash on a 74 MGB MG 13
healeyboz valve lash Spridgets 2
T MGB MGB VALVE LASH MG 9
K Kent Cam valve lash ? Triumph 2
D MGB maximum safe valve lash on MGB ?? MG 4
S TR2/3/3A tr3 valve spring compressor Triumph 5
sim looking for 2 valve spring kippers for a 948 Spridgets 3
R Valve Drain Pipe Austin Healey 13
R T-Series Valve gap for an MGTD 1953. MG 5
6 Valve Oil Seals Spridgets 10
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
P TVR Big Valve 4.3 TVR 0
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
J MGB BRAKE VALVE ? MG 11
jehuie PCV valve explanation? British Motor Corp 5
R 3000 Heater Valve Austin Healey 4
T TR2/3/3A valve springs Triumph 15
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
T TR2/3/3A valve guides and piston clearance Triumph 6
kodpkd Valve Cover Gasket - Don't do this! Austin Healey 14
KVH General Tech Heater control valve/cable Triumph 1
G Valve Train Lubrication Austin Healey 1
KVH General Tech Valve Timing--No Marks Triumph 20
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
D Water Valve Connection Austin Healey 4
R TR2/3/3A Rule 9 Valve Adjustment Triumph 8
RJS General TR Lever Shock - HD Shock Valve Triumph 2
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
M TR5/TR250 Bypass valve Triumph 27
I Bugeye valve rebuild suggestions Spridgets 8
G Valve Cover Gasket Silicone Adhesive Austin Healey 5
J Oil Pressure Relief Valve Austin Healey 3
K TR2/3/3A An alternate valve adjusting sequence? Triumph 3
K TR2/3/3A Camshafts and Valve Settings Conundrum? Triumph 7
charlie74 TR6 ‘74 valve springs Triumph 0
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
M TR6 PDWA valve Triumph 6
M Ray Juncal Valve Covers Austin Healey 5
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
BillyB62 TR2/3/3A Anyone seen a valve cover like this Triumph 0
alexisrexx TR6 Oil Sludge in Valve Cover - Normal? Triumph 16
K TR2/3/3A Brake Restrictor valve? Triumph 9
Lin Heater water valve question Spridgets 2
D MGB MBG valve clearance MG 1
A T-Series MGTD oil pump bypass valve MG 0
