MGB maximum safe valve lash on MGB ??
dansawyer
All,
I am trying to pass OR emissions with a '77 MGB. The car has a mild performance including compression and cam. The result is a chunky idle with a miss. I believe reducing some valve overlap will reduce the idle miss. What is a safe maximum valve overlap? I am thinking 20 on the intakes and 24 on the exhausts. Has anyone done this? Are those clearances on the lands or are they on the lobs?
Thanks, Dan
While I’ve never tried this myself – I have actually read a lot on the subject. The thought is that if you open up the rocker valve clearance to about 0.024" it should help compensate for the profile of the hotter cam. But I wouldn't leave it there after the test and would put it back to the normal 0.013" (warm) after you complete the emissions test.
Here is a great link on the subject.
Emissions Research info
Scroll down to the Valve/Cam timing. It has a lot of information on the valve lash procedure and how it affects your emissions readings. There are also some great links and other things to consider if your having trouble passing emissions testing.
Good luck!
You'll know not to leave the lash at .024" -- gonna sound like a marimba band!
Interesting site, Bret. Thanks!
Thanks. The plan is to try to run it through tomorrow. I have a load of gas to burn through and then to find blended regular gas. I will let you all know how it goes.
I probably don’t need to mention this but I will anyway for those that are new to this. But I would do a complete tune-up first before adjusting the valve lash. Once I adjust the valves clearance to the stock .013” settings I then go over everything – replacing the air filter, plugs (adjusted) rotor and complete all adjustments (timing idle etc.) only then would I adjust the valve lash.
Who unless you have a really “hot” came the stock settings might work. That is assuming that you still have all the original emissions equipment still in good working order. i.g. EGR valve, Cat and smog pump. Also do you know if Oregon checks the timing and idle speed? If they don’t you might be able to play with those settings a little.
Only real problem most folks with the Zenith Stromberg have is getting the air/fuel mixture set right. I am lucky in that I have a CO% Gas Analyzer to help me dial it in. If you don’t – its going to be a little harder. The Moss MGB cataloge has a pretty good procedure that should get you close. Once set I’d dial it back to lean it out before testing
Again good luck and do let know how it goes?
steveg TR6 Moss advance kit maximum advance question Triumph 13
X Technical specifications including the maximum technical weight TVR 8
charleyf TR6 Maximum overbore Triumph 7
F Problem setting timing on my BT7 - maximum distributor rotation reached Austin Healey 14
angelfj1 Operating your TR for maximum mileage Triumph 24
J What is the maximum amount of usable fuel? Austin Healey 3
steveg Maximum Advance Question Austin Healey 2
aeronca65t Maximum Midget Spridgets 11
Tronch ve Maximum axle load Austin Healey 14
healeynut BN1/2 Maximum disty advance Austin Healey 2
Westfield_XI Maximum compression ratio for A-series on pump gas Spridgets 14
60TR3A Is It Safe to Heat My Garage All Winter While I Am In Florida? Austin Healey 34
exfed12825 General Tech Electric Power Steering With Fail Safe MG 0
RAC68 Are 3-Point Seat Belts Safe in a Healey? Austin Healey 38
T TR2/3/3A Is there a Silicon safe Master Cylinder for TR3? Triumph 21
andrea LONGBRIDGE cars SOFT TOP -MOD safe water seapage Austin Healey 16
red57 Max safe EGT Racing 9
prb51 Fuel safe gasket material Triumph 5
T So - these safe to use? Triumph 16
Tinkerman Shop Safety or Safe Room Under the Car Triumph 39
B I'm no longer safe! Spridgets 23
aeronca65t Flying Teapot - Home Safe Other Cars 12
Glen_B Home safe Spridgets 1
Brosky Beat the snow - home safe in the garage Triumph 11
Randy Harris She's 41 yr. old - safe at speed? Austin Healey 37
D Safe Places for MGs MG 20
B Getting a '54 100 road safe. Austin Healey 10
BierRunner TR6 Heater Valve Triumph 12
Carlbanan56 MGB MGB valve seals MG 1
TomMull Valve lash Lotus 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
sim looking for 2 valve spring kippers for a 948 Spridgets 3
R Valve Drain Pipe Austin Healey 13
R T-Series Valve gap for an MGTD 1953. MG 5
6 Valve Oil Seals Spridgets 10
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
P TVR Big Valve 4.3 TVR 0
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
J MGB BRAKE VALVE ? MG 11
jehuie PCV valve explanation? British Motor Corp 5
R 3000 Heater Valve Austin Healey 4
T TR2/3/3A valve springs Triumph 15
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
T TR2/3/3A valve guides and piston clearance Triumph 6
kodpkd Valve Cover Gasket - Don't do this! Austin Healey 14
KVH General Tech Heater control valve/cable Triumph 1
G Valve Train Lubrication Austin Healey 1
KVH General Tech Valve Timing--No Marks Triumph 20
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
D Water Valve Connection Austin Healey 4
