T-Series td rear guards
saltiga
I have just purchased a 1953 MG td. It came complete but in many pieces, I have been looking over the parts and am curious to know why some one has welded a piece of flat about 3/4 inch x 20 gauge to the rolled edge of the rear mudguard arch. Is it an upgrade ?, is it because the guards tend to flap a little? It wont be too difficult to remove, and I am wondering is there a mod for this area? Any Ideas? Saltiga
Brinkerhoff
What you've described is how the mudguards are made. The strips are often missing or damaged but extend about 4/5ths of the length of the rolled edge and attached with short weld beads. Hope that helps.
Kevin
PAUL161
Is this what your speaking about? They keep the splash from washing around the fender and direct water down to the rear. They are tack welded on about every 6 to 8 inches. PJ
S
saltiga
Yes That is the piece I am referring, It looked , the way it is attached to be an after thought or a mod, mine is not as straight as the picture, thanks for the info. saltiga
MikeP
After years of use they tend not to be nice and straight anymore. Banged about by road debris while driving I'd guess is what bends them up.
af3683 TR2/3/3A TR-2 / TR-3 Rear Bumper Wrap Around Fender Guards Identification Triumph 0
Tinkerman TR2/3/3A TR3A Rear Fender Stone Guards Triumph 4
fad64b TR2/3/3A TR3 rear fender stone-guards Triumph 22
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
J 3000 Rear Seats Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
KVH General Tech Rear Brakes and Solid Axle Triumph 2
P Rear Springs Austin Healey 2
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
J Rear Main Seal Kit Austin Healey 1
T Looking for "BillMs rear transmission mount" Spridgets 2
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
Ed Foster T-Series MG-TD leaf rear leaf spring. MG 0
bighealeysource Burning Smell from Left Rear Wheel Austin Healey 14
R BJ7 Rear Axle Maintenance Austin Healey 5
