Wanted Square body LCS fuel pump
dezand
Looking for a used and dead square body LCS fuel pump to rebuild for a retirement project. The German made Hardi pump is preferred. Doesn't matter if the threads are stripped or not.
BobHaskell
Have you found a source for parts for the Hardi pumps? I was under the impression that they weren't available.
PAUL161
I guess this link will work?
dezand
There are no parts available for the Hardi pumps, although I was able to procure a few new point sets from ebay. The diaphragm has to be custom made, for which I made a tool to do so. The original Effbe diaphragm material is available from Europe. Otherwise it is essentially identical to the SU with brass check valves that need to be refinished. I recently rebuilt one and you end up having about $125 invested in parts and a lot of hours of time. But looking for another to do, keeps me away from the TV !
I have two Working Sq body pumps. $100 and shipping for either one
dezand
Marvin, it looks exactly the same from the outside. The exception is starting sometime in the 1960's Hardi switched from a black cap to a clear cap.
On the inside all the screw threads are metric and it is much easier to get stainless cheese head screws in metric. The SU pumps used the funky 2BA threads which you can't find stainless or even zinc plated in cheese head. The points look identical but are not interchangeable. Since the diaphragm threaded rod is metric, the std SU points cannot be used unless you swap some of the parts around. The Hardi points have a much better (simpler) way of adjusting the gap. Also, a biggie is the brass check valve design. Almost looks identical, but Hardi added a small spring and cover to the outlet valve to ensure it closes. The die cast end covers and the sand cast body have much better surface finishes inside and out on the Hardi.
I have two Hardi square body pumps, one dated 1958 and the other 1970. The 1958 one has a black cap while the 1970 has a clear cap. Otherwise identical.
I have a square body SU dated December of 1954 (from an XK 140) and it has no springs at all for the pump valves. SU only relied on gravity and back pressure to seat the valve discs. The Hardi can be mounted in various orientations due to the spring loaded valves.
BobHaskell
There were two versions of the end caps fitted to SU pumps: stamped steel and aluminum diecast. There is a spring on the lower valve. All parts are available from Burlen.
I'd like to see some pictures of the Hardi pump, showing the differences - valves, points, and? Thanks!
dezand
You are correct, the end covers were made in stamped steel and aluminum diecast, but both SU and Hardi had both. The older pumps had diecast while sometime in the late 70's or 80's, the covers were changed to stamped steel.
The early SU square body did not have the spring on the lower valve (AUB581), this was introduced later, maybe in response to Hardi having that spring ? The SU I have dated Dec 1954 does not have any springs and this is borne out by early
pump cross-section views online. I am currently in the process of adding this spring and also making the parts to modify the valve to add the secondary spring to the outlet valve disc.
This first pic shows the Hardi valve assembly. The domed disc has a small spring underneath pushing down on the normal outlet brass valve disc. The main valve housing is basically identical to the SU but has been machined deeper to account for the additional domed disc.
There is also the normal brass disc and larger spring below the valve creating the inlet valve.
This pic shows the point setup:
Here is a pic from the Healey BT7 parts manual showing no springs exist on the SU pump.
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
R Sprite Bonnet Badge 1962 Square Body Spridgets 1
R Luggage Rack for 62 Sprite [Square Body] Austin Healey 1
A Square Body Sprite Starter Motor Issues Austin Healey 2
AN5Sprite RHD square body project car Spridgets 5
AN5Sprite CL square-body Sprite Spridgets 15
Morris Square body foward tilt conversion... Spridgets 3
abarth69 Square body sprite with Bugeye rear bumpers Spridgets 14
drooartz My favorite square-body Spridget Spridgets 16
healeynut FACET Square Body Pump Woes Austin Healey 4
S TR2/3/3A ¼ fine square nuts Triumph 7
D TR4/4A square engine mount washer necessary? Triumph 6
alanjohnturner TR4/4A pesky right-ange drives , square pegs, round holes Triumph 2
Tinkerman TR2/3/3A 1960 TR 3A square spier nuts on headlight assembly Triumph 2
S Some Square Sprite Goodness Spridgets 6
Scotsman Square Drain Plug Socket Restoration & Tools 7
S TR2/3/3A square solenoids tr3? Triumph 15
Cottontop DRILLING Square Holes Restoration & Tools 12
regularman Has anyone here put a bugeye front end on a square Spridgets 2
PC power bit to square drive socket adapters Restoration & Tools 3
jsfbond Choke cable [square knob] Triumph 0
Jagboy69 Square Wiper motor needed Triumph 5
T TR2/3/3A TR3 - sloped vs "square" rear floor area Triumph 7
tweety square wheel arch 5.5" wheels will they fit? Spridgets 1
R Toyo R888 on Square Arch Spridget? Racing 4
dklawson Square Wiper Motors - Internals Spridgets 0
dklawson Square Wiper Motors - Internals Triumph 0
healeynut Square Ammeter Question Other British Cars 11
S How to seal the square hole in the firewall Triumph 14
Jayrz Bugeye rear onto square sprite? Spridgets 4
regularman Has anybody ever put a square sprite front end on Spridgets 11
George Zeck Square Headed Speciality Bolt ???? Spridgets 1
G Captured square nuts Triumph 5
aeronca65t Ariel Square Four British Motorbikes 10
D TR6 lost body shell Triumph 1
J Can a TF engine be installed in a TD body? MG 7
Got_All_4 TR6 Seal To Body Mounting Bracket Welded? Triumph 7
K TR6 Goodparts Trail arm kits mounting just to the frame( no body) and shims? Triumph 9
Editor_Reid V-12 E-Type Body Number Location Jaguar 3
5 MGA Body and Chassis Separation? MG 2
Bayless How does '67 Sprite top attach to body? Spridgets 3
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
1 TR2/3/3A Best Rustproofing for inside of body. Triumph 7
K TR2/3/3A The "wide body" TR3? Triumph 6
W TR2/3/3A Interior and Body Colours Triumph 14
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
D Body/Paint Shop Recommendations Austin Healey 1
apbos TR5/TR250 TR250 rolling chassis and body for sale Triumph 3
T TR2/3/3A Question on TR3A front body mounting Triumph 6
