Square Drain Plug Socket
Scotsman
Does anyone know where you can get a square drain plug socket to fit the plug on the oil pan, diff, and transmission of a TR3. Moss motors sell a wrench with a 7/16 head but I would prefer to have a socket. Its very easy to round off the head when using an open ended wrench as it tends to slip off.
LarryK
Sears, MAC, MATCO, Snap-on, Cobalt.
David_Doan
I got mine out with a 3/8 drive extension and a screwdriver as a shim, then replaced them with a standard 1/2" pipe plug for about $1 each.
JPSmit
Other have bought a cheap 1/2 inch breaker bar and ground it to fit.
TR3driver
Great Pumpkin - R.I.P
What you are looking for is a 7/16 "8 point" socket. Which as Larry wrote, should be readily available from Sears or any decent tool supply.
I have the sockets, but my preference is to replace the plugs with hardened magnetic hex socket plugs (that turn with an 'Allen' wrench). The plugs are just a few $$ at MMC.
Scotsman
Scotsman
I should have been more specific. The square ends of the drain plugs are male not female. ie the square end protrudes from the plug. The feedback and picture above show a female recessed square end. Sears, NAPPA, etc, etc do not have such a socket. As mentioned Moss have a wrench made for these plugs but I would prefer to have a socket that I can put on a breaker bar. I can replace plugs with contemporary plugs but would prefer to keep original.
The eight point sockets round off and strip the square plugs.
TR3driver
Right.
Well, that has certainly not been my experience. I suspect you are either thinking of a common 12 point socket, or are doing it wrong. If the plug is well and truly stuck, it might twist the plug in half, but it won't round it unless the flats were already badly damaged. I have used a breaker bar with my Sears 8 point socket many times. On occasion, when the plug was already damaged, I've had to use a pry bar to hold the socket down on the plug, but it still came out.
https://www.sears.com/craftsman-7-16-in-socket-8-pt/p-00944344000P?prdNo=3&blockNo=3&blockType=G3
00944344000
Scotsman
Scotsman
Thanks for your clarification. Yes I was using a 6 point socket. I was not familiar with the nuances between 6 and 8 point sockets. I was thinking that there would be a true square socket to fit the square head.
Point of interest. My local Sears store told me that the 8 pt sockets are no longer stocked instore and have to be ordered online. To avoid shipping costs (which are 2x cost of socket) you can go to store and order from there. They will ship to home. Sears was by far the cheapest place to order from.
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
S TR2/3/3A ¼ fine square nuts Triumph 7
R Sprite Bonnet Badge 1962 Square Body Spridgets 1
R Luggage Rack for 62 Sprite [Square Body] Austin Healey 1
D TR4/4A square engine mount washer necessary? Triumph 6
A Square Body Sprite Starter Motor Issues Austin Healey 2
alanjohnturner TR4/4A pesky right-ange drives , square pegs, round holes Triumph 2
Tinkerman TR2/3/3A 1960 TR 3A square spier nuts on headlight assembly Triumph 2
S Some Square Sprite Goodness Spridgets 6
AN5Sprite RHD square body project car Spridgets 5
AN5Sprite CL square-body Sprite Spridgets 15
S TR2/3/3A square solenoids tr3? Triumph 15
Cottontop DRILLING Square Holes Restoration & Tools 12
regularman Has anyone here put a bugeye front end on a square Spridgets 2
PC power bit to square drive socket adapters Restoration & Tools 3
jsfbond Choke cable [square knob] Triumph 0
Jagboy69 Square Wiper motor needed Triumph 5
T TR2/3/3A TR3 - sloped vs "square" rear floor area Triumph 7
tweety square wheel arch 5.5" wheels will they fit? Spridgets 1
R Toyo R888 on Square Arch Spridget? Racing 4
dklawson Square Wiper Motors - Internals Spridgets 0
dklawson Square Wiper Motors - Internals Triumph 0
Morris Square body foward tilt conversion... Spridgets 3
healeynut Square Ammeter Question Other British Cars 11
abarth69 Square body sprite with Bugeye rear bumpers Spridgets 14
drooartz My favorite square-body Spridget Spridgets 16
S How to seal the square hole in the firewall Triumph 14
Jayrz Bugeye rear onto square sprite? Spridgets 4
regularman Has anybody ever put a square sprite front end on Spridgets 11
George Zeck Square Headed Speciality Bolt ???? Spridgets 1
healeynut FACET Square Body Pump Woes Austin Healey 4
G Captured square nuts Triumph 5
aeronca65t Ariel Square Four British Motorbikes 10
R Valve Drain Pipe Austin Healey 13
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
Sopwith_Camel battery drain Jaguar 35
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
S Install drain cock in radiator. MG 2
B How big is the floor pan drain hole? Spridgets 0
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
K TR2/3/3A boot drain troughs 59 tr3 Triumph 7
R MGB BATTERY DRAIN MG 7
D Socket for TR3 Gear box drain plug Restoration & Tools 6
D TR2/3/3A Battery Box drain Triumph 9
chicken Holes for Drain Channel Pipe Austin Healey 4
B TR4/4A Oil Drain plug size Triumph 14
