DRILLING Square Holes
Cottontop
Nunyas
very cool! Though, i imagine you'd have to use that with a press that has a strong vise. I can't see using it with a hand drill ...
Billm
It is neat but since they already had to drill a pre-hole I think that it would be easier,faster and cheaper to just go ahead and broach the square hole.
BillM
Platinum
Slick!
equiprx
Yea, but can it do oval holes like I do all the time. Douh?
JPSmit
lots of stuff on it on youtube
bDJ7KYI" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"> </embed></object>
Platinum
It's a WANKEL!!!
JPSmit
JPSmit
My brain hurts :crazyeyes:
martx-5
BillM
That's exactly what I thought. However,if you needed a blind hole, then the broach wouldn't work.
Billm
Simple answer- don't design-in blind holes!! :smile:
(or- that is what my machinists keep telling me!!)
BillM
G
But them I'll need square bolts and nuts! Where am I gonna get a square tap from? :square:
B Two questions about Bugeye floor panel weld drilling Spridgets 15
S TR2/3/3A Drilling a 3/16 hole in fresh paint Triumph 1
S TR2/3/3A drilling out shifting tower for a dip stick Triumph 10
CJD TR2/3/3A Drilling spot welds Triumph 9
bigjones Drilling carburettor Spridgets 11
Tabcon Suggestions For Drilling A Hole in your EYEBALL Triumph 15
I Suggestions for drilling a hole in a grade 8 bolt? Triumph 24
K TR6 drilling into tr6 intake manifold Triumph 6
beaulieu drilling out sheet metal spot welds ? Restoration & Tools 11
T Drilling out snapped bolts - tips and techniques? Triumph 17
B Drilling oil passage Triumph 7
Bruce_B Drilling block to 11 studs from 9 Spridgets 4
Mark_Gibson TR6 Drilling Holes in a Freshly Painted TR-6 Triumph 5
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
S TR2/3/3A ¼ fine square nuts Triumph 7
R Sprite Bonnet Badge 1962 Square Body Spridgets 1
R Luggage Rack for 62 Sprite [Square Body] Austin Healey 1
D TR4/4A square engine mount washer necessary? Triumph 6
A Square Body Sprite Starter Motor Issues Austin Healey 2
alanjohnturner TR4/4A pesky right-ange drives , square pegs, round holes Triumph 2
Tinkerman TR2/3/3A 1960 TR 3A square spier nuts on headlight assembly Triumph 2
S Some Square Sprite Goodness Spridgets 6
Scotsman Square Drain Plug Socket Restoration & Tools 7
AN5Sprite RHD square body project car Spridgets 5
AN5Sprite CL square-body Sprite Spridgets 15
S TR2/3/3A square solenoids tr3? Triumph 15
regularman Has anyone here put a bugeye front end on a square Spridgets 2
PC power bit to square drive socket adapters Restoration & Tools 3
jsfbond Choke cable [square knob] Triumph 0
Jagboy69 Square Wiper motor needed Triumph 5
T TR2/3/3A TR3 - sloped vs "square" rear floor area Triumph 7
tweety square wheel arch 5.5" wheels will they fit? Spridgets 1
R Toyo R888 on Square Arch Spridget? Racing 4
dklawson Square Wiper Motors - Internals Spridgets 0
dklawson Square Wiper Motors - Internals Triumph 0
Morris Square body foward tilt conversion... Spridgets 3
healeynut Square Ammeter Question Other British Cars 11
abarth69 Square body sprite with Bugeye rear bumpers Spridgets 14
drooartz My favorite square-body Spridget Spridgets 16
S How to seal the square hole in the firewall Triumph 14
Jayrz Bugeye rear onto square sprite? Spridgets 4
regularman Has anybody ever put a square sprite front end on Spridgets 11
George Zeck Square Headed Speciality Bolt ???? Spridgets 1
healeynut FACET Square Body Pump Woes Austin Healey 4
G Captured square nuts Triumph 5
aeronca65t Ariel Square Four British Motorbikes 10
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
B TR4/4A Measurement of "IRS" badge Holes Triumph 1
M TR2/3/3A TR3 Small Mouth Inner Fender Holes Triumph 3
